Full Version: Idle Air Control Valve
frannerc73
how do you change the idle air control valve in a 2000 w reg focus?????
[quote name='frannerc73' date='06 June 2010 - 12:56 PM' timestamp='1275824818' post='84273']
hello and welcome,
what size of engine is it?
frannerc73
[quote name='stef123' date='06 June 2010 - 04:53 PM' timestamp='1275838991' post='84309']
hello and welcome,
1799
[quote name='frannerc73' date='06 June 2010 - 05:29 PM' timestamp='1275841190' post='84321']
1799
you can do it from above or below i found above easier to make room remove the airbox easiest way without touching the maf is to loosen the clamp on the airbox side remove the 4 top screws so the upper part of the airbox comes off and put to the side now just pull up on the bottom part and the airbox is out now you can get into the icv disconnect the wiring plug and simply undo the two bolts holding it in place i think they are 15mm cant remember fitting is just the reverse simple job to do
[quote name='artscot79' date='06 June 2010 - 09:20 PM' timestamp='1275855041' post='84348']
if its similar to the 1.6 engine the bolts are 8mm hex heads i think
frannerc73
thanks m8
Full Colour Version: Idle Air Control Valve
