I have a European Focus 2.0i ESP - 2000, 5 dr, manual.
The rear windscreen wiper is malfunctioning
- If switched on normally it will usually stop at far end of stroke for 20s+, and then again part way through the stroke. It continues this pattern indefinately
- if at any point when "stuck" the switch is flicked off/on, the wiper immediately resumes it's swipe
- If I use the rear windscreen washer the wipers work absolutely fine for the appropriate "timed" period
I'm thinking this could be a timer problem -- thoughts?
