[quote name='mintalkin' date='20 June 2010 - 02:37 PM' timestamp='1277044066' post='85633']
it could be just stuck,get a mate to help,hold the release lever up, then carefully ease the flap open.Once it is opened ,then lube the plastic pivot hinge and also the spring loaded release plunger.you can also locate the release cable from inside the boot behind the trim.
ok thanks i will try that tommorrow
