[quote name='sparkywilliams' date='07 July 2010 - 11:52 AM' timestamp='1278499359' post='87333']
I want to replace the front discs with new ones but there is a large nut,how do i remove disc and re-fit please?
Do i just need a breaker bar with a socket on the end?
Any help appreciated.
She is also getting her brake warning light flickering when going down hills and cornering and i've opped up fluid to well above max,any ideas? it seems a common fault on these cars.
Picture attached,thanks!!
You don't need to undo the hub nut. The discs are only held on with a spring clip and the wheel nuts/studs. They will just need a bit of persuasion with a rubber mallet or similar to let go. Warning light could be just a corroded/dirty connection.
