BMush
July 10, 2010, 3:14 pm
Hi all, hoping someone can point me in the right direction here, bought the car a few months ago, air con has never worked. When you turn on the air con, the air con light comes on, there is a boost in the amount of air coming through the vents but it is not cold. Took it down to kwik fit as they do a no fix no fee recharge. Guy said he charged it and there were no leaks, but he couldnt hear the compressor kicking in. Is there any diagnostic I can do to narrow down the problem or should I just get a 2nd hand comp and have a go?I've tried putting the system in to test mode by setting to 21, windscreen and auto, then pressing temp up and a/c together,then releasing and immediately pressing temp down, as stated on a few other articles I found, but doesn't work, just drops temp display 1/2 a degree on the last button press so not sure if there is a different combination of keys i need, it's a 2002 2.0 tdci ghia x.
Any help greatly appreciated.
jay1981
July 10, 2010, 5:38 pm
Don't know about the test mode, you could try putting a 12v feed to the compressor to see if it springs into life. By the way how much did Kwik Fit charge for the re gas?
July 11, 2010, 1:45 am
his may help.
http://fordwiki.co.uk/index.php/Climate_Control_Self_Diagnosis_Guide
BMush
July 11, 2010, 6:11 am
Thanks Mintalkin, but can't seem to get it into diagnostic mode that way either. Can anyone recommend somewhere I can take it
around south Liverpool?
BMush
July 11, 2010, 8:01 am
[quote name='jay1981' date='10 July 2010 - 10:48 AM' timestamp='1278801519' post='87808']
It was free as it didn't work.
July 12, 2010, 3:10 pm
[quote name='BMush' date='11 July 2010 - 02:11 PM' timestamp='1278853272' post='87867']
if the compressor isnt kicking in and out then theres a few possibilities 1 is that a pressuer switch is gone and needs replaced second that the temp switch has gone 3rd the compressor is knacked look in the yellow pages and pay to have a mobile aircon specialist to come out and test the system and he will tell you right away what the issue is likely the pressure switch been down that road before mbile specialist is the cheapest way
Air Con Test Mode
