Full Version: Idle Control Valve
lucas1787
Hi, Can someone tell me where the idle control valve is on my Focus 1.6 petrol Zetec Treg please. My revs are going up and down when at tick over and I have been told it could be this.So I have some carb cleaner and want to give it a clean, but I dont know where it is. Thanks Dave
It's actually more likely to be the throttle body that needs a cleaning.
rob80
its the easiest thing to get too.right at the front of the engine behind the oil dipstick,right next to the throttle body.
lucas1787
[quote name='rob80' date='13 July 2010 - 04:56 PM' timestamp='1279036018' post='88219']
Sorry for sounding thick, but what does the throttle body look like.Thanks
http://0.tqn.com/d/autorepair/1/0/h/R/throttle_body-1.jpg
That might not help you though, as that's mainly what it looks like off the car.
rob80
a thick hose will run from your airbox straight to the throttle body.the hose is actually attatched to the throttle body. you will see the jubilee clip at the bottom(opposite side is the airbox)and the idle control valve is the tiny thing next to it on the left as you look at it
vinnyvangough
[quote name='jmurray01' date='13 July 2010 - 04:36 PM' timestamp='1279034784' post='88214']
Its more likely to be the ICV thn the throttle body on the zetec's. Very very common problem
lucas1787
[quote name='vinnyvangough' date='13 July 2010 - 11:25 PM' timestamp='1279059339' post='88275']
Thanks for the info, could the throttle body cause a rattling sound when accelerating?,as it almost sounds like a butterfly valve rattling.Doesnt happean on tick over,just when putting my foot down to change gear etc. Also is this an easy bit to take off and will I need any gaskets etc?Thanks
rob80
unsure about the rattling noises you gettin.the idle control valve is dead easy.couple of screws and a clip.the throttle body has rubber around the inside but should be fine.
[quote name='rob80' date='14 July 2010 - 07:00 PM' timestamp='1279129856' post='88369']
by the sound of it it could be the butterfly valve on the throttle body is somehow loose than again ide expect that to rattle all the time idle control valve does not cause a rattle sounds like you need the car looked at incase it becomes a serious issue
Full Colour Version: Idle Control Valve
