Full Version: Focus Mk3 Towbar Wiring
mal165
Hi, I want to fit a towbar to my 59 plate focus titanium and understand the wiring through a relay etc but would welcome advice on the easiest ( and neatest) way to pick up the 12v supply to the relay. Does the feed need to come from the fuse/battery area and if so whats the best way to route this through the interior.
many thanks
herbie_flowers
Can't advise on a '59 plate but on a '55 plate there is a permanent 12v live feed in the boot for such a purpose. Get a dedicated towbar electrics harness for your car from Towsure it's a doddle to fit.
single or double electrics? single will be ok to use the 12v feed in the boot as mentioned earlier if it has one but if its double to power a split charge system then you will need a cable capable of around 30amps
mal165
[quote name='stef123' date='30 July 2010 - 09:20 AM' timestamp='1280477452' post='90515']
Hi thanks for both replies, greatly appreciated. Only planning on using single electrics for a trailer. Am I right to assume that this will be part of the 'plug in 'wiring for a dedicated kit? Can you tell me where this is a and how to identify the 12v feed?
thanks
herbie_flowers
[quote name='mal165' date='04 August 2010 - 09:13 PM' timestamp='1280952184' post='91346']
Am I right to assume that this will be part of the 'plug in 'wiring for a dedicated kit?[/quote]
The 12v feed? It's already there waiting to be used.
[quote name='mal165' date='04 August 2010 - 09:13 PM' timestamp='1280952184' post='91346']Can you tell me where this is a and how to identify the 12v feed? thanks[/quote]
If you empty the boot, carpet/spare wheel/polystyrene, on the left you should see quite a thick brown/maybe red wire with a connector on the end of it.
ferretfloozy
any idea what rating the wire is? i'd like to use it for an extra reversing light- would be using 55w front fog so min 5amp ( 2 relays of revering switch and light cluster so it opertes only at night) i live in a lane with no street lighting and one 5w bulb is rather dim.
Full Colour Version: Focus Mk3 Towbar Wiring
