JDrew1989
September 10, 2008, 9:42 am
Hey, Lately i've noticed that my passenger side footwell has been wet after wet weather, was hoping one of you may be able to help.
Also I've noticed that the passenger front tire seems to be deflating over a period of time, this i have taken to britannia tyres, they've put it in a tank and found no punctures or anything of the sort.
Thanks!
Hope you can help
James
September 10, 2008, 3:37 pm
if your car has air con check the pollen filter cover at the base of the windscreen as this is a comman area for leakage,your tyre could be a leaking valve or the tyre beads leaking
Wellz
September 10, 2008, 4:51 pm
the leak sounds like the pollen filter to me
Your tyre problem would either be a leaky valve or the tyre not fitted to the rim fully and causing a slight leak
JDrew1989
September 10, 2008, 8:40 pm
Hmm my Ka doesn't have Aircon so does that mean it couldn't be the pollen filter or?..
September 11, 2008, 4:00 am
lift the bonnet and see if the housing is there if not it could be the door card seal gone, but most likely the housing
Rikos
September 11, 2008, 6:05 am
Tyre sounds like a dodgy valve
Wellz
September 13, 2008, 5:35 pm
[quote name='JDrew1989' post='3684' date='Sep 11 2008, 02:40 AM']Hmm my Ka doesn't have Aircon so does that mean it couldn't be the pollen filter or?..[/quote]
all ka's have a pollen filter
