Rich99
August 3, 2010, 6:47 am
I've just got a new S-Max with USB connection. Although the system can read the id3 tags, it appears to only let you browse by folder/filename. So, I arranged all my albums into the correct folders, and named all the tracks 'track#'-'trackname'.mp3. However it plays the tracks back in the 'wrong' number order - by which I mean it plays track 1, then tracks 10-19, then track 2 followed by tracks 20-29 etc. Is there any way to get it to play them back in the correct order, other than going through 9000 tracks & changing all the single digit track numbers to 01,02,03 etc?
Thanks!
WillK
August 3, 2010, 4:21 pm
I would imagine you need to put a leading 0 in all the file names. I use a program called [url="http://www.joejoesoft.com/cms/showpage.php?cid=108"]Rename Master[/url] for these types of things. Should only take you about 5 minutes.
Rich99
August 4, 2010, 6:17 am
[quote name='WillK' date='03 August 2010 - 09:31 PM' timestamp='1280870503' post='91130']
Thanks for the recommendation, I'll give it a bash later on.
