leedog
August 6, 2010, 11:13 am
Hi all just a quick question. Had a diagnostics done the other day and says that injector 4 above knocking threshold. Am going to replace injector number 4 this weekend, i believe it's in cylinder 2. My question is which is cylinder number 2. Does it run cylinder 1. 2. 3 4. from left to right or 4. 3. 2. 1. from right to left.
Regards lee
August 6, 2010, 12:47 pm
[quote name='leedog' date='06 August 2010 - 05:23 PM' timestamp='1281111191' post='91636']
Regards lee
its 1234 from the drivers side to the passengers just like the ht leads would be on a petrol car number 1 is the drivers side 2 the one next to it working up to the passenger side which is number 4
leedog
August 6, 2010, 1:42 pm
Thanks alot mate. Do you know if the injectors are hard to remove or is it just a simple twist and pull thing?
dave h
August 6, 2010, 3:48 pm
Hi you carnt just replace the injector they need coding to the car with specialist equipment unless you are having your one reconditioned. Hope that helps Dave
leedog
August 7, 2010, 5:26 am
Cheers mate. Need to take the injector out to see which kind i need to order then was going to take it down to the garage for some one to fit and recode it. Hopefully that will sort it out fingers crossed.
leedog
August 7, 2010, 8:27 am
Started taking the injector apart but struggling to actually take it out now. Any ideas guys???
August 7, 2010, 9:33 am
have you got the correct socket?
https://www.portlandtools.co.uk/Automotive_tools/Diesel_tools/Ford_dura_torq_21mm_diesel_injector_socket_3934_1796.html
leedog
August 8, 2010, 11:58 am
Do i have to remove the cam cover to remove the injector or should it just pull straight out after i have unplugged all the electrics from the top?
August 8, 2010, 3:56 pm
they should just unscrew from the head without removing cam cover once the fuel pipe and electrical connectors are removed.
leedog
August 9, 2010, 7:20 am
Have taken off the fuel pipe and electric connector but they won't pull out, have tried turning them and giving them a good pull but seem to be stuck in solid
August 9, 2010, 8:00 am
try soaking with a good penatrating fluid.
leedog
August 9, 2010, 10:44 am
But i do need this socket to unscrew it do i?
Mondeo Cylinder Order
