james_60
August 7, 2010, 5:58 am
Hello
The rear most hanger on the backbox of my g/f's fiesta has corroded fully.
Can it be replaced.
The rest of the exhaust is fine and we cannot afford to spend money on a complete exhaust if its only one hanger that nees replacing.
Jamie
August 7, 2010, 6:13 am
[quote name='james_60' date='07 August 2010 - 12:08 PM' timestamp='1281178720' post='91749']
Hello
Can it be replaced.
Jamie
if the backbox is that corroded then i suspect not. a new backbox will probably set you back about £30 plus fitting unless you or someone else can do it.
August 7, 2010, 7:04 am
[quote name='stef123' date='07 August 2010 - 12:23 PM' timestamp='1281179627' post='91752']
some places might weld it but as stef said the backboxes are relatively cheap and a weld would cost around the same cash
james_60
August 7, 2010, 7:45 am
Thankyou for your replies
The whole exhaust is corrosion free its just that stupid rear exhaust hanger if you touch it pieces fall off.
A back box is around £40 it will have to wait until after our holiday which is at the end of the month.
Is it easy to fit a back box
I believe i need a hack saw some gun gum and an exhaust clamp.
Jamie
August 7, 2010, 8:12 am
[quote name='james_60' date='07 August 2010 - 01:55 PM' timestamp='1281185139' post='91764']
Jamie
£40 sounds good to me if that includes the rubber mounts and clamps required. back boxes IMO are the easiest bit of the system to replace, measure it up and cut the old one off and clamp it on. theres not really alot to it.
