[quote name='cj_wig' date='22 August 2010 - 08:49 PM' timestamp='1282505940' post='94220']
already had a vw golf
okay to change the speedo colours heres what you have to do this is for the speedo dials and the main display changing the bulbs will do nothing as they have nothing to do with the dash colours
[color="#000000"]Take out the three Philips Screws holding the dash bezel in
2) Remove the connector for the Trunk/Hatch Release Button 3) Remove the four small bolts holding the cluster into the dash
4) Using a small screwdriver, pry black lever open to release the cluster from the electrical connector. 5) Remove the cluster from the Dash
6) Pop open all four tabs to release the lens from the gauges 7) Using a TORX Screwdriver, undo the three TORX screws holding the gauges in the cluster.
8) Pull the gauge face firmly out of the cluster. You'll see some light bulbs and the LCD Display left in the cluster. 9) Using the small screwdriver, very carefully pry the black bezel off that surrounds the Raised LCD Odometer.
10) Pull the top of the LCD forward to expose the material on the back of the Display. With a fingernail or small screwdriver, peel the green tint off the back of the LCD. Keep the Green Tint, Move the Gauge components aside.
[color="#444444"][color="#000000"] Wrap the wires around each metal tab and secure them with electrical tape or optionally solder. Make sure these wires do not touch each other and that they're very secure.
[/color][/color][color="#444444"][color="#000000"] You may want to cut the plastic tabs that are on the top behind the LCD because they'll get in the way of our new electroluminescent material. Then, place the new material behind the LCD just like the old piece was. Secure it to the top of the plastic housing with electrical tape so it is out of the way of the connection for the Tach.[/color][/color][/color]
[color="#444444"][color="#000000"]Put the three TORX Screws back in the Gauge face. [/color][/color][color="#444444"][color="#000000"]14) Snap the lens back onto the cluster. [/color][/color][color="#444444"][color="#000000"] Secure the cluster in the dash with the four small bolts. [/color][/color]
[color="#444444"][color="#000000"] Re-Install the dash bezel. Remember to hook up the trunk/hatch release connector!!!
then[/color][/color]
[color="#444444"][color="#000000"]Remove the three Philips screws in the upper part of the sweeping
dash. Pull it loose.
2) Pull the wire harness off of the trunk release button behind the dash
insert.
3) Disconnect the rubber top of the steering column cover from the dash
insert. Put the dash insert in the back
seat.
4) use a 7mm hex bolt driver to remove the 4 bolts on the top and bottom
corners of the gauge unit
5) pull the gauge unit out far enough to locate the snap tabs on top
and bottom that hold the clear & black gauge front to the white gauge
back.
6) Use a flathead screwdriver or your claws (fingernails) to pull the
four tabs open. Remove the front (black & clear) of the gauge unit.
7) I had better luck installing the gauge face after pulling the gauges
out of the white housing, so I could work with it and not have to
disconnect the wire harness from the gauges. Locate the 3 TORX
(Star-shaped) screws on the front of the gauges, and un-do them, and
pull up on the black gauge face. You will not damage anything this way.
8) I pulled out the "pegs" that limit the sweep of the tach and speedo
to aid in gauge face instertion.
9) Use electrical tape to cover the exposed thin wiring going to the
face insert.
10) Slip the face over the needles. Line 'em up and you won't have to
dissect your gauges. A little force is mandatory to get it to all line
up right. Hold the face up to the light to line up things like the
upshift arrow.
11) Use some electrical or masking tape VERY SPARINGLY around the edges.
There is very little clearance after you put the black and clear cover on.
Hold it up to the cover to check. This tape will keep it lined up the way
you want it. You may also use double-sided tape under the overlays to
help hold them firmly down against the original cluster.
12) pull up on all four needles just a bit. use gentle but firm force.
none of the needles came off the spindle. I pulled all mine up about a
millimeter (thickness of a penny) to clear the thicker gauge face. You'll
thank me for this step, and if you pull a needle off the spindle, you
never read this step.
You'll have to use the Instrument Cluster
test mode to get your car idling and install your needle at the RPM
shown on the digital readout. Then you'll have to drive at 20MPH while
placing the needle on to point at 20MPH. Not fun.
13) move the electrical-tape-coated ribbon wire out of the way, and plug
the face plate back into the lighted white casing, and replace the three
TORX screws. Replace the "pegs" for the tach and speedometer. flip the
needles to the original positions (0 MPH and 0 RPM) They're magnetic, so
they can spin around and around and around all day long with no adverse
affect.
14) start the engine. I know that it's not put together yet.
15) Play with the needles. Rev it. Drive around. Make sure the needles
aren't sticking or dragging on the new face. If they do, pull 'em up a
bit more. Make sure they're calibrated (see other postings) if you wish.
Maybe make sure your upshift light is lined up still?
16) Snap the front cover back on. Make sure all 4 snap connectors engage.
Examine the face for showing tape and anything strange. If everything
looks good, snap it together.
17a) For setting the indiglo's up to operate with only the provided
brighness control: tap the positive wire of the transformer into #47.
use a fuse piggyback, or just pull the fuse out, and jam it in while
pushing the fuse into position.
17b) For Wiring it to dim with your stock dimmer control AND the one
provided with the set: Reach up inside the fuse panel and remove the
wire harness from the back of the headlight switch. Find the wire
that's Orange with a blue stripe (not black) and splice the red wire
to this orange/blue one.
18) I grounded the black transformer wire to a screw I saw next to the
fuse box.
19) I mounted the indiglo controls to the "flap" thing under the fusebox
access panel.
20) Fish that pesky indiglo wire out and plug it into the farthest plug
on the transformer.
21) wrap up excess wire and hold it out of the way with zip ties or
something.
22) turn on headlights. Make sure indiglo works. Helpful to pull under a
tree or into a garage. Change the color & brightness.
23) If they don't work, your set is defective or you didn't follow my
instructions, or these instructions are wrong.
24) if they work, put the 4 seven-millimeter bolts back in the four
corners of the gauge assembly taking care tomove the indiglo wires
out of the way. Short Circuits - BAD!
25) Get the dash insert out of the back seat and get it close to position.
26) tuck the rubber part of the steering column under it
27) attach the wire harness for the trunk release
28) snap the dash insert firmly into place and put in the 3 screws to
hold it in.
29) Wait till dark and have fun!
the footwell lights turn off with standard bulbs they will not with leds in them as led are low voltage so they will continually stay on
or get a zetec and take the dash from that
[/color][/color]
