Lippo
September 13, 2010, 3:11 am
The wife's CMax started playing up the other day. I knew for a while that she couldn't open the boot using the switch, only the remote button could unlock the boot. No big deal, so we left it.
However, a couple of days ago, the boot started opening at random times, mainly when the car was started. It quickly progressed to opening whilst driving or sticking it into reverse.
I had a look on here and the internet. It looked like I might have to shell out a few quid for a new switch. I read that recently someone had used a small button switch from a mouse, so I thought I'd have a go at that before giving my hard earned cash to the people who designed the car badly in the first place!!
Tools required....
Hex bit for screws in grab handles
10mm spanner (ratchet spanner preferred)
Soldering iron and solder
An old computer mouse
Superglue
Silicon sealant.
This is what I did;
I removed the 2 screws in the grab handles at the bottom of the bootlid cowl. Then I gently prised the cowl off the bootlid. This was surprisingly easy to do and none of the clips or plastic broke.
I then loosened the 4 nuts that hold the outer plastic trim using the 10mm spanner (where the boot switch is located) onto the boot. I prised this away from the bootlid and pushed in the grey plastic clips on the side of the switch mechanism which released it. I then unplugged the switch from the loom and removed it from the car (along with the grommet). (You can see I had 3 switches lined up to see which fitted best, 2 were from the mouse and one was from an old led bike light)
[IMG]http://i998.photobucket.com/albums/af102/lippo999/ec7246ff.jpg[/IMG]
I peeled back the rubber 'gaitor' from the switch and found the same white powdery stuff that others have found, which meant that water ingress was probably to blame. I gave this a good clean and had a play with the switch to see if it still worked. The multimeter told me it was intermittently faulty.
I removed the original seal where the wires join the switch and pushed the switch out from the bottom of the plastic trim.
[IMG]http://i998.photobucket.com/albums/af102/lippo999/b8e64668.jpg[/IMG]
I found an old mouse and butchered it. I got out my old soldering iron and removed a couple of hopeful switches, stabbing myself in the palm in the process. I am a rubbish solderer, so if I can manage it, everybody else can!!
[IMG]http://i998.photobucket.com/albums/af102/lippo999/e291c5ed.jpg[/IMG]
I cleaned up the plastic trim and dried it thoroughly.
[IMG]http://i998.photobucket.com/albums/af102/lippo999/4e959165.jpg[/IMG]
I then de-soldered the original switch. I fed the wires back through the little gap and soldered the new switch on. Took me half an hour because I'm terrible at it. A couple of burns later and it was done.
[IMG]http://i998.photobucket.com/albums/af102/lippo999/d27e0448.jpg[/IMG]
I had some strong superglue lying round, so I used that to fix the new switch in place, making sure it lined up with the button in the trim.
[IMG]http://i998.photobucket.com/albums/af102/lippo999/ce799ac6.jpg[/IMG]
I didn't have any clear silicon sealant so some white anti-mould shower sealant had to do the job. I plugged up the hole by the wires thoroughly with the sealant and made sure it was neat inside the trim.
[IMG]http://i998.photobucket.com/albums/af102/lippo999/cb14f4d2.jpg[/IMG]
[IMG]http://i998.photobucket.com/albums/af102/lippo999/17d47c0e.jpg[/IMG]
Next up was putting the rubber trim back in place. Some careful application of the sealant later, and the whole switch was watertight (hopefully).
[IMG]http://i998.photobucket.com/albums/af102/lippo999/a718e7eb.jpg[/IMG]
[IMG]http://i998.photobucket.com/albums/af102/lippo999/bea0fb35.jpg[/IMG]
I put it all back together and for the first time in a couple of years the boot opens using the switch. The random problem of it opening seems to have stopped as well.
It's early days but looks promising. Only took an hour or so and didn't cost me a penny either!!
This seems to be a common problem with CMAX's and Focus' between 04 and 07. I've put this in a couple of places as well to help as many people with this problem as possible.
Dickster555
September 14, 2010, 3:04 am
Hi Lippo
Thanks very much for this, i have problems with mine intermittantly not working (it doesn't open itself but sometimes doesn't open at all - the number of times i've emptied the boot by folding the rear seats down!!!).
I'm going to strip mine down now i know its so easy, thanks again for the well illustrated info.
Richard
Lippo
September 14, 2010, 10:19 am
Hi Dickster,
If you haven't got a mouse to dissect, I had a quick look on Maplin and found the following which seems similar to my switch;
http://www.maplin.co.uk/Module.aspx?ModuleNo=4196
These seem to be around the right size; SWT105 4.3mm Black or SWT105A 5.0mm Black.
Or these;
http://www.maplin.co.uk/Module.aspx?ModuleNo=2493
http://www.maplin.co.uk/Module.aspx?ModuleNo=2492
I haven't seen physically seen these but the type/size seem about right. Good luck!
Craig
Dickster555
September 14, 2010, 10:57 am
Thanks for that, i'll let you know how i get on in the next couple of weeks
mrdwat
December 31, 2010, 9:27 am
I must say a big thanks to Lippo, i have a 54 c max and the other day my boot would not open,i had a old dvd player which didnt work and got 5 little black micro switches out of it,followed Lippos instructions and 10 mins later my boot works again.the photos were a big help. Andwill have saved me a few pounds.many thanks again Lippo
isherdholi
January 2, 2011, 9:42 am
I just did this for my wife's Mk2 Focus and the boot switch now works perfectly. Thanks so much Lippo!
wolfenstein
January 8, 2011, 7:26 am
thanks lippo
johnmcc
June 9, 2011, 12:15 pm
Thanks for this thread - I've just done the repair to my bootlid catch with a micro-switch from an old computer mouse. It works!
JuniorAshe
August 1, 2011, 3:09 pm
My boot latch had been annoyingly popping open every few weeks for about a year; then a few weeks ago the frequency suddenly increased so that it seemed to pop every time I got back in the driver's seat after slamming the boot closed!
I found this great thread from a Google search and I followed Lippo's instructions. It all worked perfectly (apart from a few burns from inexperienced soldering) and a great feeling of self satisfaction has set in. It takes me back to the old days when you could really do DIY stuff on your car.
So thanks Lippo, for saving my sanity; I couldn't have taken the aggro for much longer ;-)
Lippo
February 7, 2012, 5:06 am
I'm really glad that people found this useful. Mine is still working perfectly, even in the freezing weather.
Jackms1878
May 24, 2012, 3:06 pm
I know this is an old thread but i stumbled across it a couple of days ago whilst trying to find an answer.
My Focus (MK2) boot handle was not working since i bought the car whitch i didn't really mind as i just used the key. But it started unlocking on its own unless the car was locked. This got really annoying really quick.
Iv searched around any there docent seem to be a definitive answer. Mainly just people saying that it was down to water ingress.
so i thought id have a little mess with it and see what i could do.
I peeled back the rubber of the boot handle to find i full to the brim with water and a white power/residue
After i seen how bad it was i took it apart from the inside and gave it a good clean. Wiped everything and gave anything Easily detachable a good soak in the sink.
It was a hot day so i drove around without the Rubber on the handle to air it out.
And then Blasted the handle and cover in WD40 (to evaporate any left vapour).
Since putting it back together its been fine. The boot handle still does not work (in need of a new switch). But it sees to have fixed the unlocking problem.
Hope this helps.
cynondiver
May 27, 2012, 9:45 am
Having read this thread I decided to try and change my own switch.
Not wanting to attempt repairing or soldering I took the decision to buy a new one.
I bought a genuine Ford part from a main dealer for £12, much less than I had been led to believe on here.
In fact I looked on ebay first and they all wanted £30+
Changed the switch in less that 30 mins
st3v3o
February 3, 2013, 6:29 am
Big thanks to Lippo for an easy to follow guide that took no time at all to fix my annoying self opening boot well chuffed an im not bothered if i have to do it again in six months because of how quick and easy it is to fix .......great post tnx.
February 4, 2013, 9:30 am
An excellent guide, I will pin this appropriately. I will have a word with the other mod's and see if we should have a CMAX "Guides" section, or wether we shall move it to the general "guides" section...
