starfield
September 19, 2010, 8:29 am
i have got a 56reg focus zetec. My question is: Has it got a knock sensor to vary the ignition?
starfield
September 21, 2010, 8:56 am
anybody???
mross
September 21, 2010, 12:22 pm
im looking into it, not sure on this one.
mross
September 21, 2010, 1:33 pm
apparently yes it has if its the 123 bhp duratech unit according to Haynes manual via a friend, im not 100% on this so have a look, it should be located on the right hand side of the cam cover near the top of the ignition leads, your looking for a small black plastic unit about the size of a small match box attached to the head with a multi-plug connected to it, hope this helps.
starfield
September 22, 2010, 3:14 pm
i am assuming the car has got a knock sensor. here is the next question:
has the car got variable valve timing?
mross
September 22, 2010, 5:43 pm
Hi starfield
have a look at the thread " TO VCT OR NOT TO VCT " two posts up from this one, i have talked scoby through this very same question, you will find the answer there mate.
starfield
September 23, 2010, 1:58 pm
[quote name='mross' date='22 September 2010 - 10:53 PM' timestamp='1285195409' post='98384']
Hi starfield
but scoby is referring to the 1.6, i have got a 1.8
mross
September 24, 2010, 9:23 am
Hi Starfield
Doesn't matter what the engine size is, on duratech petrol engines with TI-VCT you will see the four sensors on the cam cover, if they are not there then its not a TI-VCT engine.
Take a picture of the engine and post it here if your unsure.
starfield
September 25, 2010, 8:28 am
[quote name='mross' date='24 September 2010 - 02:33 PM' timestamp='1285338187' post='98551']
Hi Starfield
I can see four thick wires or cables on the right hand side of the engine. they are near the top.
i have taken a few pics from my camera phone. i hope the resolution is ok and will shed some light.
mross
September 27, 2010, 1:01 am
Hi Starfield
im 100% certain that this engine is not a TI-VCT unit (has no variable cam timing), sorry if this disappoints you mate.
starfield
September 27, 2010, 2:26 am
[quote name='mross' date='27 September 2010 - 06:11 AM' timestamp='1285567279' post='98830']
Hi Starfield
what are those 4 cables / wires on the right end of the engine?
mross
September 27, 2010, 3:54 am
mross
September 27, 2010, 3:56 am
Judging from the pics they look like vac pipes, are they rubber or metal pipes ?
starfield
September 27, 2010, 11:41 am
[quote name='mross' date='27 September 2010 - 09:06 AM' timestamp='1285577786' post='98842']
rubber
mross
September 28, 2010, 4:01 am
They are vac pipes.
mross
September 28, 2010, 4:05 am
They are vac pipes.
