darrensmith
September 20, 2010, 12:40 pm
[quote name='zev' date='20 September 2010 - 11:00 AM' timestamp='1284976232' post='97974']
Yes sorry lol.I've done as you said sat in the car and tested the gears. It very quietly squeaks in all gears but louder in reverse and 4th. Its from the gear stick and inside the car. My gear stick is covered by material and not easy to get to from inside. Hope that describes the problem better .
zev
ok ill put a read through together for ya now
remove the plastic trim that the leather gator is attached to
lift the trim and gator up out of the way
clean up and mess, dust etc, be careful not to got to hard as you dont want to damage anything. be aware that there are some important electrical stuff there.
then add a few drops of light oil etc. work the gear stick until the squeak is gone (hopefully).
there are a few other plastic linkages there if the squeak is coming from them u can always dab them a bit of oil/grease with a cotton bud.
try not to use to much on the gearstick ball joint just a few drops and work the stick you dont want it swiming in oil just enough to reduce wear.
hope this helps
