Full Version: Focus Mk 1 Spluttering At Low Revs
slyp98
hey there the missus car focus 2003 1.4 lx has been acting up , i replaced the coil pack about 2 months ago, now it has developed another coil like symptom , when driving along and having to slow down a bit , when you accelerate again the engine coughs and splutters until the revs rise only happens for a couple of seconds really annoying in town as you have to keep dipping the clutch , any help appreciated thanks
[quote name='slyp98' date='27 September 2010 - 07:31 PM' timestamp='1285611702' post='98910']
could be plugs and or leads could be an emissions pipe as well ide start with the plugs and leads first
slyp98
i'll have luke at the plugs but i replaced the leads when i did the coil pack , which of the pipes are the emissions ones cheers, how about that cowdenbeath , spl next year i reckon !!!
[quote name='slyp98' date='27 September 2010 - 09:07 PM' timestamp='1285617442' post='98928']
was it a genuine coil pack with ford leads or a cheap coil pack with cheap leads the reason i ask is the cheap ones are so bad they can fail almost instantly especially the leads and coil
slyp98
[quote name='artscot79' date='28 September 2010 - 12:25 PM' timestamp='1285672545' post='98978']
i'm afraid they ere of the cheap variety , and the leads too , i think i paid 70 euro for both
[quote name='slyp98' date='04 October 2010 - 03:07 PM' timestamp='1286200625' post='99771']
a false economy mate the cheap ones are crap casuing bad misfires right from the start the ford plugs are in our cash 64 quid yiou wont get genuine ones any cheaper than that as for the coil pack these are genuine and good priced http://cgi.ebay.co.uk/COIL-PACK-IGNITION-Focus-Mondeo-fiesta-OE-FORD-not-COPY-/390059606545?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ad15d4211
slyp98
i've checked the coil pack secondary res. between cyl 1 and 4 is 10.5 k ohms and between 2 and 3 its 10.7 k ohms , primary res. bet 1 and 2 its 1.1 ohms and bet 2 and 3 its 1.2 ohms could they still be duff? also the revs rise and fall from 450 to 900 rpm at idle when the lighs are switched on , which i thought would lead to the alternator but i checked the output and its a steady 14.75 volts , i suppose it could be the rectifier , would this show a different output reading if it was shot ??
graham16v
Just fixed a problem like this on my wifes 1.4 focus.
If you look inbetween the inlet manifold (black plastic manifold on front of engine) you will see 2 rubber pipes coming off the engine, 1 from cyl 1 and the other from cyl4.
These 2 pipes join a T-piece which connects to the positive crankcase ventilation (PCV) valve.
One of these pipes might have a split.
The pipe connected to cyl 1 was split on my wifes car and caused a misfire when cold and poor idling.
slyp98
thanks graham16v , i replaced this also ,problem part like a few more on these focus's , i put a new set of plugs in yesterday and it seems to have helped , even though the old one''s didnt look bad, only 47k on the car ? i have replaced the coil pack plug leads power steering pump, the rubber t junction , all in the space of 3 k !!
[quote name='slyp98' timestamp='1287131283' post='101026']
the plugs should be gapped at 1.0mm they come pregapped at the old setting which was 1.3mm this can cause issues also use some lithium spray grease give a short squirt into the ht leads this stops moisture and for some reason helps its a ford thing that they dont tell you but it has cured many a misfire spray a bit on the coil end of the leads too that 9/10 times solves any issues
slyp98
cheers mate did that with a bit of grease , put new plugs in er and it seems to be better , its still hunting at idle i have checked the secret menu in the dash and i'm getting a dtc error d0262 , which reads in the online posts as injector cyl 1 high circuit , i guess that means new injector
