Full Version: runing problems
azyman
every time i start my car from cold i get big clouds of blue smoke, so much ul hav troble to see in front of you.
any sugestions wot it could be?...
blue smoke is a sign that your engine is burning oil, it may be due to a blocked PCV (positive crankcase ventilation) system or the valve seals. The oil could be coming up through the rings. A wet/dry compression test will tell that.
azyman
[quote name='mintalkin' post='4871' date='Sep 22 2008, 05:36 PM']blue smoke is a sign that your engine is burning oil, it may be due to a blocked PCV (positive crankcase ventilation) system or the valve seals. The oil could be coming up through the rings. A wet/dry compression test will tell that.[/quote]
ok chers for that ill hav to check those i did think that it might be the valve seals but wurnt to sure i have got another cylinder head to go on it but its is a injection head and my car is carb will it still fit?
Full Colour Version: runing problems
