colinr
September 30, 2010, 11:54 am
Hi to all
I have an escort van 55 1800 endura non-turbo 02 on a 51 plate .Could any one tell me what make of fuel pump and fuel injectors are fitted to this model/year.bocsh or Lucas I am having a few problems so want to change the injectors a friend as two sets of injectors both Lucas both from 1998 escort vans part numbers LCR6705601-E and LCR5705402-D
Are injectors interchangeable will Lucas fit if a bocsh pump is fitted, is there any where I can obtain the correct part numbers for the injectors or find out if these injectors will fit. I do not want to take out my injectors just yet as I have been stold I will need to get some new protection heat washers if I take out the injectors also are there any seals fitted to the top of injectors when connecting to the fuel lines and are they available to buy also what size INJECTOR HEAT SHIELDs
lublin
October 3, 2010, 1:10 pm
[quote name='colinr' date='30 September 2010 - 07:04 PM' timestamp='1285865680' post='99303']
Hi to all
Hello. Wouldn't it be best to go to a main dealers as they could tell you if the injectors are the same for the models you listed? They will also know what washers/seals you need.
colinr
October 4, 2010, 2:28 pm
[quote name='lublin' date='03 October 2010 - 07:20 PM' timestamp='1286129442' post='99668']
Hi and thanks,
I managed to get a number off my injector’s looks like they are Lucas
Also been to main dealers bosch or Lucas injectors will fit ,But could not give me any info on injection fuel pump as Lucas and bosch are both fitted .Looked at some photos on eBay looks like a Lucas pump (as Lucas injectors are fitted ?) Heat injector washers
£20.00 for 4 (rip off) Will have a look around see if I can get them cheaper
