Full Version: Clutch
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford Galaxy Club
jericho200
i have a problem getting into gears i have been told that the clutch might need bleeding can this be done?
if so how would it be done?
many thanks
jericho200
it's a 96 galaxy
dezwez
[quote name='jericho200' timestamp='1287303575' post='101241']
it's a 96 galaxy
get a haynes manual it should be in there :)
if its hydraulic you can bleed it, if its a cable you should be able to adjust it.
bleeding hydraulic clutches is a PITA at the best of times, really needs to be pressure or vacuum bled.
mrcabbie
hi m8
sorry to be the bearer of possibe bad news,but i had the same problems and turn out to be the flywheel siezed.are you getting any vibrations through the car?if so then you're looking at flywheel and clutch
Full Colour Version: Clutch
