Full Version: Wheel Offset on 2002 Mondeo Tdci LX
zetecman
[font="Comic Sans Ms"]Hi to all the other mondeo lovers out there!.
This is my first post, so bear with the new boy. I am in desparate need of the the following information. Can anybody tell me what the maximum offset is (in mm) that I can put on a 2002 Mondeo TDci LX ? Any help would be great.
Zetecman[/font]
the controller
Copied staright from Ford E-TIS, hope this helps
The Controller
Suspension System - General Information - Specifications Mondeo 2001 (10/2000-02/2007)
Print Report An Error
Front Wheel Alignment (at kerb weight) — Caster (Vehicles with 1.8L, 2.0L, 2.2L or 2.5L engines)
Model Decimal Degrees Degrees and Minutes
Nominal Tolerance Range Nominal Tolerance Range
4-door and 5-door +2.59° +3.62° to +1.56° +2° 35' +3° 37' to +1° 34'
Wagon without load levelling shock absorbers +2.83° +3.85° to +1.81° +2° 50' +3° 51' to +1° 49'
Wagon with load levelling shock absorbers +2.70° +3.72° to +1.68° +2° 42' +3° 43' to +1° 41'
Maximum caster variance left-hand side to right-hand side 1.00° (1° 00')
Front Wheel Alignment (at kerb weight) — Caster (Vehicles with 3.0L engines)
4-door and 5-door +2.68° +3.70° to +1.66° +2° 41' +3° 42' to +1° 40'
Wagon with load levelling shock absorbers +2.79° +3.80° to +1.78° +2° 47' +3° 48' to +1° 47'
Front Wheel Alignment (at kerb weight) — Camber (Vehicles with 1.8L, 2.0L, 2.2L or 2.5L engines)
4-door and 5-door -0.65° +0.63° to -1.93° -0° 39' +0° 38' to -1° 56'
Wagon -0.66° +0.61° to -1.93° -0° 40' +0° 37' to -1° 56'
Maximum camber variance left-hand side to right-hand side 1.25° (1° 15')
Front Wheel Alignment (at kerb weight) — Camber (Vehicles with 3.0L engines)
All vehicles -0.84° +0.43° to -2.11° -0° 50' +0° 26' to -2° 07'
Front Wheel Alignment (at kerb weight) — Total Toe Setting (Vehicles with 1.8L, 2.0L, 2.2L or 2.5L engines)
Derivative Tolerance Range Setting Adjustment, if required
All variants (decimal degrees) -0.00° (Toe-out) ± 0.35° -0.00° (Toe-out) ± 0.14°
All variants (degrees and minutes) -0° 00' (Toe-out) ± 0° 21' -0° 00' (Toe-out) ± 0° 08'
All variants (mm) -0.0 mm (Toe-out) ± 2.5 mm -0.0 mm (Toe-out) ± 1.0 mm
Front Wheel Alignment (at kerb weight) — Total Toe Setting (Vehicles with 3.0L engines)
All variants (mm) -0.0 mm (Toe-out) ± 2.8 mm -0.0 mm (Toe-out) ± 1.1 mm
Rear Wheel Alignment (at kerb weight) — Camber (Vehicles with 1.8L, 2.0L, 2.2L or 2.5L engines)
4-door and 5-door -1.07° +0.18° to -2.32° -1° 04' +0° 11' to -2° 19'
Wagon without load levelling shock absorbers -1.22° +0.03° to -2.47° -1° 13' +0° 02' to -2° 28'
Wagon with load levelling shock absorbers -1.13° +0.12° to -2.38° -1° 08' +0° 07' to -2° 23'
Rear Wheel Alignment (at kerb weight) — Camber (Vehicles with 3.0L engines)
4-door and 5-door -1.33° -0.08° to -2.58° -1° 20' -0° 05' to -2° 35'
Wagon -1.37° -0.12° to -2.62° -1° 22' -0° 07' to -2° 37'
Rear Wheel Alignment (at kerb weight) — Total Toe Setting (Vehicles with 1.8L, 2.0L, 2.2L or 2.5L engines)
All variants (decimal degrees) 0.28° (Toe-in) ± 0.35° 0.28° (Toe-in) ± 0.14°
All variants (degrees and minutes) 0° 17' (Toe-in) ± 0° 21' 0° 17' (Toe-in) ± 0° 08'
All variants (mm) 2.0 mm (Toe-in) ± 2.5 mm 2.0 mm (Toe-in) ± 1.0 mm
Rear Wheel Alignment (at kerb weight) — Total Toe Setting (Vehicles with 3.0L engines)
All variants (mm) 2.2 mm (Toe-in) ± 2.8 mm 2.2 mm (Toe-in) ± 1.1 mm
Torque Specifications
Description Nm lb-ft lb-in
Tie-rod end locknut 40 30 –
Stephen Browning
Hi there and thanks to the Controller for posting the data for the Mk III
I'm currently having difficulty finding the Alignment data for the MkIV.
As it is a much larger car with, it appears, a longer and wider wheelbase, I take it the geometry is very different.
For example, taking the front Total Toe, I've had avice that it should be 0.0 (as the Mk III) or +1.4mm . Anyone know which is correct
Ta and Regards
Steve
cjax
All that info but it doesn't answer the simple question about the maximum offset :blink:
Stephen Browning
From what I have as regards the Mk III
Front Total toe 0.0mm +/- 1mm 0degrees 0' +/- 8'
Rear Total Toe +2.0mm +/- 1mm. 0degrees +17' +/- 8'
Which means I assume the Front toe is allowed to be between -1mm and +1mm, or -8' to +8' (' = minutes of arc, 1' = 1/60 degree)
Does that help?
And now back to the Mk IV
Aligned on a Hunter system today which I think it has the same data as the Corghi I've used before....
And, the data they have is different from that for the Mk III and previous. But then the Mk IV is longer and wider (Ford trying to recreate a Granada??) and does therefore, I assume, have different geometry.
So, for info, here is what I have found out this morning
Hunter Alignment System - Ford Mondeo Mk IV (2007 on) 2.0TDCi (140PS)
Data Front Half Toe +2' to +10' Total Toe +4' to +20' Vehicle set to L/R +6'/+6' Total +11'
Data Rear Half Toe +8' to +16' Total Toe +16' to +32' Vehicle set to L/R 10'/11' Total +21'
So it will be interesting to see what info our experts have. The average MPG is usually a good guide to whether a Mk IV has gone out of alignment!!
Regards
Steve
