Full Version: Electrics Issue
monty187
Hello All,
I am having an issue with my 2.0 2005 Titanium Focus. It started a few weeks back and began with the central locking not working everytime. With the fob or key in lock. After a few attempts the key opened the door. But only the drivers. After this brake warning lights and engine warning lights have been on a few times. Finally now the indicators are not turning on. Any ideas what is going on here? Anyone every had an issue like this? I have tried another keyfob with no sucess.
Monty
[quote name='monty187' timestamp='1290435651' post='104568']
Hello All,
Monty
diagnostics is the best bet here check under pass side for water ingress and check in the boot behind the arch cover theres 2 multi plugs there if you have a leak from the boot hinge rubber it goes down into this plug which runs lights indicators etc to the rear other then that check all fuses in the glovebox
monty187
[quote name='artscot79' timestamp='1290442014' post='104587']
Thanks a million for that, ill have a look round those things tomorrow in daylight and let u know how it goes. Thanks again :D
monty187
Think I may have figured it out, partly anyway. I replaced a bulb last week, when I took it out again the locking and indicators are now working. will get a diff bulb and see if that solves it.
[quote name='monty187' timestamp='1290515950' post='104661']
cant see why that would make a difference unless its the incorrect non compatible bulb i suppose its worth a try
monty187
Changed the bulb again and everything worked ok until I restarted the car. Now central locking screwed and indicators not working. Will ring the mechanic tomorrow. Cheers for the help :0)
Full Colour Version: Electrics Issue
