Full Version: Puma Front Suspension
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford Puma Club
peez
Hi,i have a 98 puma that always had knocking in front left corner,i decided to replace the complete wishbone,as i found reasonably priced replacement and eliminate 3 possible bushes,old ball joint was totally knackered,since replacing it,the knocking is not as bad but has developed a occasional small clunk and rumble on left lock in gear and neutral,i suspect car has hit a kerb or speed bump quite hard,can anyone help with other possiblities or experienced the same problem? thanks
Parkesie
Left cv joint could be on its way or wheel bearing. An outside chance that its the Anti roll bar bushes but id be looking at the cvjoint as most likely culprit.
Full Colour Version: Puma Front Suspension
