stuffandblah
November 28, 2010, 11:36 am
Can anyone give me an idea of the kind of common faults with the latest focus please?
I have a mark 2 1.8 TDCI focus, which over the years I've had a few mechanical things go wrong such as DMF, clutch, intercooler, etc... I'm looking to get a 2007/2008 focus. Is the 2.0 TDCI a good engine?
Dave
hillmangimp
November 28, 2010, 12:11 pm
[quote name='stuffandblah' timestamp='1290965761' post='105244']
Dave
The 2.0 is a more modern design and you'll probably notice its more refined and quieter than the 1.8 with a good step in performance as well. The problems you describe with your 1.8 are sadly common to a lot of diesel engines nowadays. The only real specific problem with the 2.0 TDCI will be leaking injector seals and split intercooler pipes. These will be easy to spot/hear. Other problems (such as dpf and dmf) are again common diesel problems. Just make sure the car has a service history and that it behaves well on the test drive. Otherwise the engine has lots of pull and is fuel efficient.
stuffandblah
November 28, 2010, 12:24 pm
Thanks for the info.
Does the 2.0 TDCI have a DPF, or is this only on specific models?
I know the VAG 2.0 TDI 170 have a few problems with DPF and a few people are getting them removed and remapped. Are people getting similar issues on the ford range?
Does make me wonder if I should just get a petrol to be honest.
hillmangimp
November 28, 2010, 1:03 pm
If you're looking at 2007/2008 then its extremely liklely it will have a dpf as thats when Ford started making them standard on the 2.0 tdci, prior to that it was an option on this engine. Look the 2.0 tdci is a grat engine if its reliable, however moden day diesels are not as robust as they should be. When they go wrong its a big repair bill in a lot of cases. I have a 2.0 tdci and the performance is strong but If I was buying for me I would not buy diesel (unless its a VAG PDI unit). Petrol is more expensive on fuel and tax but much easier and cheaper to maintian.
Common Problems
