noddy
November 30, 2010, 1:17 am
Wondered if anyone had a similar problem to my windscreen where the de-icer has just started to only do one side and in stripes.
Does this mean it will soon stop working altogether?
More importantly, does it mean a new windscreen as that sounds expensive?
I fear the worst.
Gazjs
November 30, 2010, 3:10 am
If you are on about the heated screen. I believe that each side works on a different fuse. So give the fuses a check
noddy
December 22, 2010, 1:52 am
Thanks Gazjs.
I should have thought of looking at the fuse.
You were right. I transposed the fuses over and the fault swapped sides. One fuse £5.36 though!!! A special, big fuse apparently!
