Full Version: Water Pump Question
weedavey1888
hello chaps
my little fusion has developed a coolant problem.the thing is ive never owned a ford so not too familiar with the engine. but basicaly it developed a leak and i think its coming from the pump. the pump squeals but i'm not sure of the exact location . looking from the timing belt side of the engine .is it the lower lefthand pooley that is driven by the v shaped fan belt. and if so. to change the pump do you need to remove the TIMING BELT. or just the V SHAPED FAN BELT. any help would be much appreciated. thank you in advance
[quote name='weedavey1888' timestamp='1291575889' post='105913']
hello chaps
the lower left hand pulley, is that the water pump?? not too familiar with your engine but the water pump should be driven from the serpentine belt that does the power steering and alternator. this means the pump can be changed and the timing is unaffected. on my 1.6 the water pump pulley is smooth - the smooth edge of the belt drives it.
weedavey1888
thanks for your input. glad it aint powered by the timing belt
tommy.h
Hi Davey
this any help?
tom
Marcy133
What age is your Fusion? From 56ish onwards you'll need to remove the timing belt to do the water pump, but the earlier ones you do not need to, both require removal of the alternator though. If you haven't got to do the timing belt it's a nice little job and should only take a couple of hours.
weedavey1888
thanks for all your help guys . pump is driven by the serpintine belt. job done :D :)
Full Colour Version: Water Pump Question
