NukeProof
December 12, 2010, 11:57 am
Hello Fellow members - recently my drive-shaft went so i got that sorted but here's the thing, Now when i press and depress the clutch pedal its really rough as if its grinding metal on metal. What could this be ? it changes gear fine and the bite point is the same which is why im a bit confused???? please help !
lublin
December 13, 2010, 8:42 am
[quote name='NukeProof' timestamp='1292176679' post='106533']
If it has a cable clutch then it could be the cable is frayed or incorrectly routed. There isn't something fouling the actuating leaver on the gearbox, is there?
NukeProof
December 15, 2010, 3:49 pm
No i finally gave up and asked a mechanic who said it was something called a quadrant. Now from ford there £15 but as ive been reading up on this a little it seems quite tricky to do! any suggestions ?
lublin
December 16, 2010, 6:46 am
[quote name='NukeProof' timestamp='1292449790' post='106869']
I found this on the web:
Seat out "tick"
unhook cable
Shaft out
drop pedal
fit new quadrant
shaft in
fit cable
Pump pedal till adjusted
But if you have a pre 95 model then you can mod it.
http://www.apracing.com/info/info.asp?section=Escort+Clutch+Pedal+Modifications_90
vinnyvangough
December 18, 2010, 1:14 pm
Yea the quadrants are cheap as chips to buy but a total sod to replace. Most people say to allow best part of a day to change it.
Rough Clutch Pedal
