harryp
December 16, 2010, 7:19 am
Hi
Im new to all this but i need to change the alternator on my 2001 2.0DTTi mondeo estate is this going to be a hard job to do?
I so far have limited myself to doing my own brakes but due to lack of funds im having to expand my knowledge.
I need to know if i am going to need any special tools? or if the is it best to access the alternator from the top or bottom of the engine?
Like i said im relativly new to tinkering about with the more intermate parts of the engine so i would even have a little trouble locating it to start off with, but once im there im reasonably technically minded as im a sheet metal/mechnical engineering technician. and once i have my head round what it is that im doing im usually ok.
so if anyone could help me out with any advice it really would be a big help.
Harry
tommy.h
December 16, 2010, 11:16 am
Hi Harry
if you are reasonable at DIY you should find it a doddle.
it is not that hard just a couple of spanners. (be careful when unplugging the electrics though)
tom
fishpond 47
December 16, 2010, 11:42 am
[quote name='tommy.h' timestamp='1292519775' post='106946']
Hi Harry
(be careful when unplugging the electrics though) BATTERY MUST BE DISCONNECTED
tom
sorry for adding to your post Tom.
tommy.h
December 16, 2010, 11:49 am
[quote name='fishpond 47' timestamp='1292521339' post='106953']
no problem fishpond all input welcome none of us are perfect. think my memory is on it's way out anyway.
harryp
December 17, 2010, 6:32 am
thats good to hear
thanks tom
i read in the haynes manual that i need to remove the rod ends (which requires a ball joint seperator) to make room to remove the alternator through the wheel arch?
is that really nessecary because i know that the manual it shows the correct procedure but there are often shortcuts that are not mentioned.
tommy.h
December 17, 2010, 10:22 am
Hi Harry
sorry can't help there.may be someone else will be able to.
tom
Alternator
