December 19, 2010, 3:06 pm
[b][i][font="Comic Sans MS"][size="4"]Hi all,
What size of screw or bolt is required to fit the engine cover to a 1.6TDCI.
I’ve recently purchased the engine cover but it didn’t come with any screws or bolts for fitting to the engine, I’ve checked the engine and theirs white grommets (Cup Holes) that match up with the holes in the cover but there’s no threads in the grommets, so don’t want to try make my own bolts,
Has anyone on here got an engine cover fitted to theirs and could you post a picture of the bolts holding yours on please[/size][/font][/i].[/b]
focusian
December 20, 2010, 7:53 am
Hi Lenny ! i can show you here some pictures of 2.0 TDCi 2009 engine cover.
You can see the bolt mounted on engine and hole for bolt beneath of the cover.
Hope it's same as 1.6 ............
bottletree
December 20, 2010, 1:21 pm
I'd like to know how to get the bloody thing off. I can unscrew the obvious one on top of the cover, but the one to the side is an awkward sod. How do you get that off?
December 20, 2010, 1:54 pm
[quote name='bottletree' timestamp='1292872915' post='107284']
from looking under my cover, try removing the screws then push (dont Lift) just push it towards the windscreen and it should slide up then lift off, please post a picture of the screws you have removed.
focusian
December 20, 2010, 8:28 pm
one more picture...............
December 27, 2010, 2:28 am
Dont do what I did, I unscrewed the top bolt on my 55 plate, and then just pulled, put a nice little crack in the bottom right hand of the cover! and I cba to buy a new one!
October 31, 2012, 5:56 am
[quote name='Lenny' timestamp='1292792767' post='107221']
Well its almost two years in my attic, and I'm finally going to fit it.
I've been in touch with ford to purchase fixings. But they need a 1.6TDCi that has the part factory fitted in order to supply me with the parts.
So if anyone has a 1.6TDCi with factory fitted engine cover
Could they PM me their VIN so as I can aquire the parts from ford?
StanH
October 31, 2012, 7:06 am
Does an engine cover reduce noise by much?
November 1, 2012, 5:46 am
[quote name='StanH' timestamp='1351685174' post='214627']
In theroy it should mate, but bonnet insulation would be better at reducing noise levels.
And BUMP!
Can anyone help me with a VIN or Ecat images of parts to fit my 1.6TDCi engine cover to the engine for the first time.
alexp999
November 1, 2012, 2:12 pm
Is your engine/cover like this?
http://www.tdocuk.com/viewtopic.php?f=41&t=4537#p47368
I'm looking through Ford E-Cat at the moment, trying to see if I could get that to fit to my Fiesta
StanH
November 1, 2012, 2:37 pm
Stoney should be able to help - he said this in the Green Cotton thread
"Got around to fitting my filter last night, what a doddle.
Remove engine cover, undo jubilee clip on pipe, undo six Torx screws around the filter housing, swap filters and reverse."
November 1, 2012, 3:33 pm
The engine cover for a 1.8 is different.
On mine though it's 4 plastic bolts from the engine block that have rounded heads that the cover clips onto.
salsheikh
November 1, 2012, 3:48 pm
Lenny, is this any good?
[url="http://www.ebay.co.uk/itm/FORD-FOCUS-C-MAX-ENGINE-COVER-1-6-TDCI-2007-ON-/140877620180?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20ccf5e3d4"]http://www.ebay.co.uk/itm/FORD-FOCUS-C-MAX-ENGINE-COVER-1-6-TDCI-2007-ON-/140877620180?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20ccf5e3d4[/url]
November 1, 2012, 4:28 pm
[quote name='alexp999' timestamp='1351797125' post='214858']
Yes thank you,
That is identical to the engine cover I have ready to fit.
But I've contacted ford and they want a VIN to match a 1.6TDCi with engine cover so as they can supply parts.
I'll try PM the focus owner thanks mate.
November 1, 2012, 4:33 pm
[quote name='salsheikh' timestamp='1351802904' post='214872']
Thanks mate.
That's the exact part I have and will fit the 1.6TDCi engine on all ford but I need the parts to mount to the engine or a VIN of a car that has one already fitted so as ford can supply the fittings to mount it.
alexp999
November 1, 2012, 4:35 pm
[quote name='Lenny' timestamp='1351805292' post='214874']
Yes thank you,
The parts you should need from what I can see are:
1x 1347930
1x 1347932
2x 1364348
That will give you the two (different) bolts and two nuts.
Still worth checking with a VIN, if you can. I'm going to see if I can get hold of the parts and fit one to my Fiesta, only thing that concerns me is bonnet clearance, but I think it will be ok.
alexp999
November 1, 2012, 4:38 pm
Also, I find this while doing a bit of hunting. Its not in English, but ti details that parts I was talking about and has a few pics throught the thread of people wanting to do the same thing:
http://www.idaf.it/index.php?topic=1857.msg179477#msg179477
November 2, 2012, 4:13 am
[quote name='alexp999' timestamp='1351805727' post='214876']
1x 1347930
1x 1347932
2x 1364348
[quote name='alexp999' timestamp='1351805883' post='214877']
Thanks for all of this information Alex mate,
I've sent some emails to ford with the above part numbers, hopfully when they enter the part numbers it will show them an image of the cover etc. And they will get back to me with all parts required.
I appreciate the links too, because my laptop broke last august and my only online device is a 7" android tablet and it drives me nuts. But I'm too busy spending on the car to buy a laptop, maybe in the january sales I'll bag a bargin one.
But I'll update this thread with my progress in sourceing the parts required to fit the engine cover. And any part numbers to help others aswell as yourself.
November 2, 2012, 5:39 am
Quick update:
I've read through the thread linked and saw invoice images with prices.
Now I can't understand one word but judging by the prices it seems the engine cover part number for the 1.6TDCi is 1684950
Then their is various discussions about parts etc. But all mention the following part numbers and Qty's
1 x 1347930
1 x 1373324
2 x 1347932
2 x 1355877
2 x 1364348
I've emaild ford for an invoice on these parts, without the actual cover itself then the bill should be under 30 pounds excluding postage judging by the other site.
alexp999
November 2, 2012, 6:21 am
[quote name='Lenny' timestamp='1351852748' post='214906']
Quick update:
1 x 1347930
1 x 1373324
2 x 1347932
2 x 1355877
2 x 1364348
1347930 - p/n for left bolt (when viewed from front of car)
1373324 - bracket with ball end. May not be needed on the newer engine cover with two screw holes (old version had only one hole)
1347932 - p/n for right bolt (when viewed from front of car)
1355877 - old p/n for nuts
1364348 - current p/n for nuts
November 2, 2012, 6:33 am
[quote name='alexp999' timestamp='1351855315' post='214910']
Excellent stuff.
I'll download the fitting images from the other site and upload to my photobucket then put them here too.
Ok,
As previously mentioned here are the images from the other forum.
The first image shows a focus with the Peugeot/Citroën engine cover fitted, interesting to see that Cover doednt overcast the turbo like the ford one does, Perhaps due to heat but I much prefer the ford cover personally.
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/funbrd-1.jpg[/IMG]
In the next image you can see the old style of ford 1.6TDCi engine Cover, its longer and wider than the facelift cover but will still fit a facelift 1.6TDCi engine.
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/12669hh-1.jpg[/IMG]
And here are some images of the facelift 1.6TDCi engine cover:
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/img0269cl-1.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/47139296.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/img0270o-1.jpg[/IMG]
The fittings required to mount the cover are different depending on the cover,
But I have purchased all of them from ford so I will soon know what part numbers are required for each specific style of cover.
From closely examining the images it seems that the ball joint bracket that fits on the induction side above the fuel filter,
And the ball joint bolt that fits to the intercooler pipe. Both of these parts seem to be required for fitting the larger style of cover only.
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/23mq6is.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/2u9mknc-1.jpg[/IMG]
The smaller facelift engine cover saw in the image below seems to require two bolts and two different styles of nuts as you can see in the images below:
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/76620887.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/30018769.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/12244289.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/27983810.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/260abt1.jpg[/IMG]
November 3, 2012, 4:53 am
Further update;
I've been in contact with ford and purchased the following parts to fit my facelift engine cover, i have purchased all brackets and bolts for both styles of engine cover because I'm not 100% sure what exact parts I'll need but I'm sure I have what will be required to fit both style of cover, so I may be selling some fittings onwards.
Here is my shopping list;
Ford-Engine Noise Cover Stud Part Number: 1347930(QTY1) Retail Price: 9.99
Ford-Engine Noise Cover Stud Part Number: 1347932(QTY2) Retail Price: 9.99each
Ford-Engine Noise Cover Nut Part Number: 1355877(QTY2) Retail Price: 1.92 each
Ford-Engine Noise Cover Stud Washers Part Number: 1364348(QTY2) Retail Price: .81p each
Ford-Inlet Manifold Bracket Part Number: 1373324(QTY1) Retail Price: 11.31
alexp999
November 3, 2012, 7:02 am
Be good to hear your progress on this Lenny.
I'm going to experiment with fitting one of these to a Fiesta, and if it goes well I'll post a thread in the Fiesta Club detailing what is needed.
I can't believe the price on the bolts though! £10 for a bolt?!?!
November 3, 2012, 2:45 pm
[quote name='alexp999' timestamp='1351944171' post='215015']
Thanks mate,
I'm posting as much detail as possible on this subject in order to help others as best possible perticurally those searching via Google etc.
Who are not yet members of the forum, because this topic has had over 2,000 views so it must be a popular part that people would like to fit on their ford.
And regarding the bots costing 10 pounds.
I think they are a custom built bolt specific for the purpose of mounting the cover with double ended threads.
But I reckon thes two bolts and two nuts is all that is required to fit the facelift cover, but we will know for certain in the coming weeks.
I owe you a pint for linking me to the other forum, that had the discussion on it
That link was a great leap in the two year quest to find the part numbers.
My engine cover is curently being colour coded but should be complete by Saturday 10th November and hopfully I'll have the fixings then too.
I plan to create a guide for the focus section too so between us; we will have both models coverd.
And I've found www.fordpartsuk.com to be slightly cheaper than the prices quoted above.
grahamp
November 5, 2012, 10:04 am
What I'd like to know is why did my 1.6TDCi come without one? And the 2 others I lifted the bonnet on come to think of it..
November 5, 2012, 6:26 pm
[quote name='grahamp' timestamp='1352131489' post='215333']
Mine didn't have one neither,
And according to ford no 1.6TDCi engine on the 2008-2010 focus has one fitted because Ecat says its not an available part.
Eventhough it fits the mk2.5 perfectly and is available as standard on high spec mk2 focus models aswell as Cmax
alexp999
November 7, 2012, 8:22 am
Hey Lenny,
I have got a cover through now for my car and offered it up, it won't be a straight forward fit for the Fiesta (I didn't expect it to be if I'm honest), but I think I can make it work. (Going to need trimming slightly to clear surrounding parts. (As the engine bay is obviously more cramped in a Fiesta).
One question though, before I got the cover, I assumed the bolts went into those white plastic holes but can now see that Ford don't use them. Instead they seem to actually be integral to holding some bits of the engine in place. On my car, when I shine a torch through the mounting holes of the cover, I can see heads of bolts.
What is it like on your Focus? Do I assume that these special mounting bolts actually replace the standard bolts, hence why they cost more?
I don't want to start undoing bolts on the engine unnecessarily!
Cheers.
November 8, 2012, 6:30 am
[quote name='alexp999' timestamp='1352298141' post='215679']
Hey Lenny,
Cheers.
Hi Alex,
I too have the white grommet caps around different spots at the top of the engine, but i dont think these get removed in order to fit the cover.
However i do believe two bolts do need to be removed and replaced with two of the double-ended bolts from ford.
But i think its two black headed bolts that get removed and not those with the white grommets over them.
I have recieved the parts ordered from fordpartsuk.com
As you can see in the image below, the bracket is huge lol but wont be required.
I reckon i just need the two bolts on the top right of the image and the two nuts on the bottom left. Perhaps the square spring washers too on the lower right of the image.
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2430.jpg[/IMG]
alexp999
November 8, 2012, 6:33 am
Yeah thats what I meant. I had thought the white grommets got used, but instead it seems you have to remove two bolts holding parts of the engine together and replace them with the special stud/bolts which then provide a way of mounting the cover.
I have ordered some parts from the same place, how long did they take to come through?
Also let me know how you get on and I will do the same, although I am going to need to cut a few bits out of the cover to make it fit the Fiesta
November 8, 2012, 6:50 am
[quote name='alexp999' timestamp='1352378010' post='215799']
I placed the order on the 3rd November and arrived via post this morning 08th shipping from uk-ireland takes 3 days so your looking at 5 days leed time.
Unfortunitly im now in the situation where ive got the fitting kit but no engine cover lol
I phoned body shop this morning and it will be the 17th at the earliest when my parts are ready for collection but ill keep you and the thread updated on the progress.
November 13, 2012, 2:23 pm
quick update:
Engine cover and parts returned from body shop, going to be busy when i get some free time in dry day light.
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2469.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2470.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2479.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2477.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2468.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2467.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2473.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2472.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2471.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2474.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2480.jpg[/IMG]
November 13, 2012, 2:35 pm
Oooh shiny
salsheikh
November 13, 2012, 2:38 pm
looking good Lenny. Word of warning - do not get too close with a pressure washer as it can lift off the paint so be wary if your using one or go to a carwash that use them! other than that, get a move on and fit the bits!
alexp999
I ran out of daylight to take some pics, but I got the cover fitted to my Fiesta (after some adapting), definetly makes it quieter and warm quicker.
I ended up using the following parts:
[font=Banner][size=5][font=Times New Roman][size=3][color=#000080][font=Times New Roman][size=3][color=#000080]1347930 (left stud)[/color][/size][/font][/color][/size][/font][/size][/font]
[font=Banner][size=5][font=Times New Roman][size=3][color=#000080][size=3][font=Times New Roman][color=#ff0000][font=Times New Roman][size=3][color=#000080]1449591 (right stud)[/color][/size][/font][/color][/font][/size][/color][/size][/font][/size][/font]
[size=3][font=Times New Roman][color=#ff0000][size=3][font=Times New Roman][color=#ff0000][size=3][font=Times New Roman][color=#ff0000][font=Times New Roman][size=3][color=#000080]1364348 (washer)[/color][/size][/font][/color][/font][/size][/color][/font][/size][/color][/font][/size]
The bracket that the rubber grommet/ball joint goes into was already fitted on my car (bizarely enough).
Looking forward to seeing your fitted
November 13, 2012, 2:46 pm
[quote name='alexp999' timestamp='1352839109' post='216614']
Thanks mate,
Please help a brother out and upload some pics in daylight so as i can picture it a bit better,
I was hoping for saturday but its missus birthday tomorrow and ive promised to take her shopping saturday so hopfully sunday ill get the black loom conduit changed to blue and fit some parts.
November 13, 2012, 2:53 pm
[quote name='Stoney871' timestamp='1352838912' post='216611']
Oooh shiny
[quote name='salsheikh' timestamp='1352839082' post='216612']
Thanks very much guys,
Ive to collect the front splitter on thursday or monday at the latest, very pleased and all for 200euro
Couldnt beat that price.
Full days work ahead though fitting black headlights and blue conduit prior to fitting panels, all coming togeather though,
And thanks for the heads up on the grills with power hose. I dont wash the car myself but ill make sure those who do, dont go too close, but how do i get all the bugs off 5he front end now?
Ow and it wouldnt be complete without the original warning Decal from ford on the slam panel.
1.74 lol
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2436.jpg[/IMG]
salsheikh
November 13, 2012, 2:56 pm
they normally use traffic film remover which helps but get yourself a jet machine and some snowfoam which helps remove the crap better. cheaper in the long run too. ask tdcist, he spends 6 hours cleaning his car (when he gets time)
November 13, 2012, 3:17 pm
[quote name='salsheikh' timestamp='1352840199' post='216621']
Thanks mate,
Ill have a look out for a power washer in the january sales, along with a netbook instead of this 7" testicle
Doing my head in not having a proper keyboard to tap it out on. And local guys offer wash and chammie dry for 10euro so if i bought a washer for 90 then thats less than a years wash and i could clean the driveway too, unless they bring in the apposed water charges lol
jg321
November 13, 2012, 4:26 pm
[quote name='Lenny' timestamp='1352161614' post='215433']
1.6 TDCi on a 58 plate here, came with a cover.
Brigante
November 13, 2012, 4:32 pm
The colour coding is looking very nice mate I have to say. Bargain price too.
Look forward to seeing it all fitted, especially the splitter when you get it back.
November 13, 2012, 11:40 pm
[quote name='Brigante' timestamp='1352845923' post='216652']
Thanks mate,
Think ill start a new thread for the results, because it takes this one off topic a bit and first thing ive gotta do is swap all black cable conduit to blue to give some contrast to all the black and silver.
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2456.jpg[/IMG]
November 14, 2012, 11:53 am
I think i may be missing a metal washer plug from my pre-owned engine cover
Ive just noticed when refitting the rubber plugs, one of them doesnt have the metal part.
Did yours have two or one?
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2487.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2485.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2488.jpg[/IMG]
[IMG]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2486.jpg[/IMG]
Brigante
November 14, 2012, 1:38 pm
[quote name='Lenny' timestamp='1352871649' post='216680']
Thanks mate,
[img]http://i575.photobucket.com/albums/ss192/lennymanwoods/Image2456.jpg[/img]
I look forward to seeing the results of the blue conduit mate
TDCiST
November 14, 2012, 1:44 pm
HAHA i've just seen this!!
Yes sadly i do... and its due for a clean!! maybe friday! (I do have work at 5pm tough...
alexp999
November 15, 2012, 1:58 am
[quote name='Lenny' timestamp='1352915588' post='216758']
I'll have to take mine off and have a look. It will give me a chance to picture the bolt positions too.
I don't get much chance to photo my car in daylight other than the weekends, but I'll see if I can do it at lunch time today.
alexp999
November 15, 2012, 9:22 am
Managed to grab some pics, will post a link to my thread in the Fiesta club when I have done it, but I did check, and I have that metal bit on both sides of my cover as you can see:
[img]http://dsvmoqvwmd0c4.cloudfront.net/uploads/imgs/tng_1352992937__img_20121115_141917.jpg[/img]
November 15, 2012, 1:30 pm
Thanks mate,
Think ill be able to purchase two washers in the local DIY store and place one top and bottom to replicate the missing one,
Because they come as part of the cover and not available seperately.
salsheikh
November 15, 2012, 1:37 pm
ooh, my cover doesnt have any material underneath it, just plastic.
alexp999
November 15, 2012, 3:36 pm
My guide is up:
http://www.fordownersclub.com/forums/topic/37930-guide-fitting-an-engine-cover-to-the-16-tdci-90ps-non-dpf-2008-to-mid-2010-fiesta
And before and after pics if your interested :
http://www.fordownersclub.com/forums/topic/36265-my-fiesta-mk7-with-its-recent-updates-56kdata-warning/#entry216990
