Full Version: Dials/gauges Not Working?
Ford Owners Club - Ford Forums > Ford Models > Ford Escort Club
Zoggy
[b][i]Hi, i have recently bought a Ford Escort [b][i]1.8 [/i][/b]SI [98], it's in pretty good condition considering its age, there's only a few annoyances i need to take care of, b[/i][/b][b][i]ut the most immediate thing i need to sort are my dials,my oil gauge isn't working,and when driving at [x]mph, the speed dial needle hovers and wobbles quite a lot around the actual speed im doing,surly this should be steady?,everything else works fine though! [/i][/b]
[b][i]
[/i][/b][b][i]Does anyone know how to fix this annoyance please?[/i][/b]
[b][i]
[/i][/b]
[b][i]Thanks for any help in advance![/i][/b]
1987 xr3i cab
i mate check your speeddo cable is plug in propley
RShaun
Spedo bounce is a common fault on fords, if you`re lucky then its a loose cable but it normaly turns out to be the drive wheel in the g/box, not too big a job to sort just a pain in the arse!!
Check all the plugs on the dials as its probably loose conections
Full Colour Version: Dials/gauges Not Working?
