Full Version: 04 130Bhp Galaxy Wipers Stopped Working
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford Galaxy Club
D4v1d
Hi everyone first post here, But it's a fault I need fixing.
I went out to the car yesterday, started it fine, then noticed that the wipers didn't turn on. Then I remembered that once the wipers wouldn't wiper across the windscreen unless the car was moving forwards (I thought this was really weird) so I tried to wash the windscreen and the wipers didn't respond at all. The rear wiper works fine.
The fuses seem fine, I looked at the wiper motor today, It all seems fine at a quick glance. I drove the gear box with a spanner to the mid stroke, when I turned the ignition on, the wiper motor drove to the parked position but wouldn't drive as to wash or wipe the wind screen, Is there some thing I'm missing?.
Jouxy
Could be a couple of things,firstly the wipers work on what we call the lin bus signal circuit.The alarm system also works on this circuit. The alarm siren is prone to water ingress which then corrupts the wiper operation. I have also experiened relay problems, there are 2. Hope this helps, Jouxy.
D4v1d
Thanks Jouxy.
I went back to the basics and started to go through the fuses one at a time. I found that a 10amp stated as a fan fuse had blown. I replaced it and the wipers started to work straight away. I thought that the wiper fuse was listed as a 30amp fuse.
I have a MkII Galaxy 04 130Bhp, Is the fuse identifier for the fuse box correct on this car?.
Jouxy
Fuse listings are poor plus sorry for the info I thought you had later shape galaxy, if you need any more fuse info let me know
tommy.h
Hi d4v1d
see attached these should be correct for 2003-06.
tom
