Full Version: 2002 Focus 1.4 Power Steering Pipe
cobes1981
Need some help, had a leek in power steering system and eventually tracked it down to a pipe, it is the one which comes out of the rack after removing a bracket and then just pulling the pipe out, it then joins onto a flexi which goes up and under the airbox and battery tray and joins onto the cooling pipe behind the radiator on the nearside. The pipe is leaking on the metal part, not sure what this is made of, this is my first question. Also could anyone tell me whether this is a High pressure pipe which I would be better getting replaced completely or is it one of the lower pressure pipes which a could maybe seal up with some hose and jubilee clips?
dezwez
[quote name='cobes1981' timestamp='1294519924' post='109104']
you would be better getting replaced completely
then you no the job is a good one try a breakers yard. :)
