Full Version: Help Me Plz
Ford Owners Club - Ford Forums > Ford Models > Ford Escort Club
l3onxr
hi all iv brought a 2002 escort van 1.8 diesel 55 ian im having trouble with it it is strugling to start so i changed glow plugs fuel filter and air filter but has made no diferance at all can any 1 plz help me
lublin
If it were mine I would: use injector cleaner,
look for damp areas (diesel) along the fuel lines near the pump/injectors because fuel out = air in and you might be pumping the air through after it's been stopped a while,
also have the nuts on the pump been spannered i.e. has someone altered the pump timing or been messing with things,
does it smoke whilst driving indicating either burning oil (worn engine) or worn injectors,
how does it run as, if the valve clearances have gone tight it will have reduced compression and so poor starting and running,
does it turnover fast enough or is there a problem with this (could be a few things)?
Full Colour Version: Help Me Plz
