al & cat wilson
January 31, 2011, 11:15 am
Hi all.
We are Alec and Catherine, we had a Mondeo 2.0 tdci about 3 year ago and desided to get a landrover freelander to pull our caravan better as it been a 4x4 ( what a mistake ) so now we have managed to get ourselves a fantasic Mondeo 2.0 (130) ghia x in black and we love it.
The only problem we have is somtimes when we start the car it will start then stall after a second or two somtimes it will take 2 or 3 attempts to start correctly or it will start but sound like a bag a hammers the revs will not lift any more than about 500 rpm then rise to normal speed after a few seconds and the engine runs fine .
Can any one shed any light on this problem ? advice much appreciated .
Thanks Alec .
MoneyHead
February 5, 2011, 3:21 am
Hi Alec, I have the very same car TDCi 130 Ghia X in black! having the same problem, mine starts fine from cold but if you start when warm it takes up to four trys then starts but like yours the revs stay at 500 rpm and the ECU light for a few seconds and then clears and the revs are fine again. Does your ECU light come on as well? I have been told by a garage that it is the EGR valve causing the problem, I will let you know if it fixes the problem when I have it replaced.
taffg
February 5, 2011, 4:23 pm
you may want to search the forums as someone posted an egr valve strip and repair with photos and saved a small fortune,but i cant locate it!
February 6, 2011, 8:12 am
bad statring from warm on the tdci is a well known problem and there is a pmc update from ford to cure it.if you want to clean the egr valve see here.
http://www.fordwiki.co.uk/index.php?title=EGR_Valve_and_Inlet_Manifold_Clearout_TDCi
al & cat wilson
February 6, 2011, 3:45 pm
Thanks guys your advice seems invaluble next weekend you will find me in garage head under the bonnet spanners in hand wish me luck ;)EGR valve here i come
al & cat wilson
February 6, 2011, 3:51 pm
[quote name='MoneyHead' timestamp='1296897679' post='112696']
Hi moneyhead ,
What a car we love it . check out the other posts sound not to hard and could save us some money ?
where you at in the uk ?
Poor Starting
