Full Version: Worn Suspension
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford Puma Club
martpuma
Hi I have a Puma which i purchased last November, it's a 2000 model with very low miles 28,000. I have replaced both the upper top mounts and the front wishbones but I think the suspension may also need changing. It's passed the MOT but my question is will a 10 year old car that has low miles still suffer from worn suspension? When I brake it does feel like it dips quite a bit at the front and on the motorway to me feels like it bobs about a bit.
If it is worn would I need to change both the struts and springs or just struts? I don't want to keep spending money on the car but if this will sort out the ride it will be worth it as in most ways the car is in nice condition.
fordpartsman
the best way is to test to bob and rise of the suspension, if you push down on the front corners, they should have a maximum bounce of 1, this means when you release they should go up, then go down and up again and then stop, bear in mind if its less its good
this is the test for the dampers as it checks the resistance created by them
martpuma
[quote name='fordpartsman' timestamp='1296516718' post='112125']
Thanks I have done this test and it doesn't seem too bad but i'm sure i read somewhere that with Mcperson struts this test isn't as good as the struts can be worn but not show when doing this bounce test. I don't think they are knackered but not giving the sporty feel they once did. Unless it is something else that is worn and not suspension itself?
It's a difficult one as I don't want to spend more money on something that doesn't need replacing but at the same time would like to improve the ride/handling of what is a great little car.
btmaldon
Are you getting any lean on fast cornering? The Puma should remain pretty well level on corners.
vinnyvangough
If YOU feel you want better handling etc i would change it. I'd go for a set of 30mm lowering spring and new shocks.
martpuma
[quote name='btmaldon' timestamp='1296568606' post='112181']
Yes it does lean a bit more than i would expect, I'm sure my original puma which I had a few years ago didn't lean like this one, also when hard braking I really feel the car rock forwards on the suspension more than I remember. But then again it was a while ago I had my last one
martpuma
[quote name='vinnyvangough' timestamp='1296575579' post='112199']
Not sure how much this will affect my insurance though as I am on a multicar policy which works well on unmodified cars
martpuma
Any particular brand setup that you would recomend?
vinnyvangough
PI are good, GAZ are fantastic, lots out there
Full Colour Version: Worn Suspension
