Full Version: How To Remove Radio?
JOHN31
hi
does anybody have instuctions on how to remove the 59 reg s max radio because i need to get the serial number to get the code lol
thanks a lot
john
johnH
if its the same as the focus headunit. you will need 4 removal keys...you can do it with 2. they slot in gap you see around 4 of the buttons on the corners. the gap looks like a knife blade slot, if that makes sense
JOHN31
[quote name='johnH' timestamp='1297017524' post='112901']
thanks a lot for that i will have a look and see what i find, at one time it was simple lol
thanks again
john
137699
On a 59 reg you probably have the oval shaped radio - in which case there are no "knife-slots". If that's the case you will need to remove the button fascia above the radio (the one with the hazzard switch on) and the console around the gearknob & handbrake, then you will be able to get to the four screws which hold the centre panel on - remove this then you can pull out the radio.
It's meant to be difficult as it's an anti-theft measure.
Full Colour Version: How To Remove Radio?
