Full Version: How Can I Tell If Have A Dpf Fitted To My Focus?
APJ
Hi Guys,
Probably a stupid question which has a simple answer..............how can i tell for certain if my 2.0TDCI 2005 Focus Saloon Titanium has a DPF?? isnt clear in the owners manual. Im guessing it most probably has?
Version: Series 40
Engine: 2.0L Duratorq-TDCi (136PS) - DW10
Transmission: 6 Speed Manual Transaxle - MMT6
Emission: 2000 EEC (EEC 7)
cheers,
johnH
apparently its only the 1.8tdci engine that doesnt have a dpf or additive the others in the series do...along with the dreaded DMF!
APJ
dam so mine will definatly have one. Nothing wrong with it as yet.....but i know im gona have issues with this at some point. where is the DPF located?
johnH
from what i have been told it is connected to the same bit as the cat converted...as in it splits in two, one side has cat other has DPF. but from what i have been told on other sites, you can clean the DPF instead of replacing as they (ford) will just give you a cleaned refurbed one anyways. there is another thread on the focus side of this forum regarding this and has links to guides (for peugeot- but should be similar).
Karlos
[quote name='APJ' timestamp='1297675534' post='114046']
I have the 2.0 TDCi Titanium, but mine is an '07 plate. I do not have a DPF on mine, which is a bit of a bonus. I doubt yours would have one either tbh.
One fairly obvious way to check - when you drive along at night and accelerate from around 1500rpm through the 2000rpm area under load/in a fairly high gear, if you see a bit of smoke behind you in following car's headlights, then you probably don't have a DPF.
APJ
[quote name='Karlos' timestamp='1297763572' post='114209']
hmmm, how do you know for sure you havnt got one Karlos? JohnH suggested that it was only the 1.8TDCI MK2's that didnt have DPF's fitted. As yet i havnt had a chance to look under my car to see if there is something resembling a DPF around the Cat converter area as its dark when i get up to leave for work and dark when i get home:-( gona have a look at weekend to try and finally work out if i have one! Cant believe its this hard to work out if my car has one fitted. cos its quite a major part. Is there something in the engine bay i can look out for which will indicate wether i have one??
On my way home tonight i will try out your suggestion of accelerating hard between 1500rpm and 2000rpm to see if i can see any noticable smoke. Im praying i havnt got a DPF fitted as they sound like a bloody nightmare when they go wrong.
johnH
its only what i have been told, so i could be wrong about the 1.8TDCI engine being the only one.
to check to see if you have a DPF would be to take of the catalitic converter and have a look for the filter. to check to see if you have the additive tank, just look under your car at the fuel tank and a smaller tank will be located there filled with eolys fluid or such like. i dont think nothing in the engine bay will point this out.
johnH
an easier method, would be to write down your VIN and Reg, phone your local ford dealership and ask them...they will tell you in a matter of minutes if you have one fitted or not. lol
APJ
[quote name='johnH' timestamp='1297777257' post='114242']
Hi John,
I have now emailed Ford as didnt get a chance to phone during my lunch break! hopefully they will reply swiftly. if not will phone em. Will also try and have a look under my car to see if can see eolys fluid tank next to main fuel tank. thanks for all the suggestions guys:-)
johnH
no worries...also you can have one and not the other aswell as both...such as you can have a dpf and no additive tank...if that makes sense, so i wouldnt assume you dont have a dpf if you dont see the tank.
hopefully this will be usefull for you.
APJ
ok.....wont assume i havnt got one if dont see tank then John.
nothing we dont already know but thought id include the link anyway.... http://www.theaa.com/motoring_advice/fuels-and-environment/diesel-particulate-filters.html
Mooresey
Do you have to fill up for the additive to be added or can you just put as much as you like in and it will add it?
johnH
from what i understand is the car measures how much fuel is in the tank to begin with (before filling), measures how much fuel you have added, calculates how much additive is needed and adds it. it uses minute amount....apparently 1 litre can get you 40k miles (motorway driving as main) or so i am told.
hope that helps you
APJ
Will a light come on on my dash if the Eolys needs topping up?
p.s still awating confirmation from Ford as to wether my Focus was fitted with a DPF when it was first built
No Lights I dont believe, unless the system reports a malfunction...
johnH
from what i have read on other forums (related to different cars) the engine management light comes on when it is getting low...however do not keep going untill the fluid has totally emptied otherwise you will be buying a new filter. im not too sure on fords tho jee knows his stuff so he could be right.
i know for defo on peugeot units a engine management light and "depollution fault" shows followed by limp home mode!
unfortunately you can top the fluid yourself (if...if you can get hold of the fluid) but you will need the dealer to reset the counter on the ecu.
APJ
yeah maybe an error will come up on the display rather than a warning light on the dash. i guess ford didnt think it was worth putting another warning light on the dash for something that only needs changing 2-4 times over the course of the cars entire life
Why make something simple? I suppose the way they would see it, is if you knew why you went in, they would lose £60.00 a time (minimum!)
APJ
On the Parkers website it suggests my model of Focus does NOT have a DPF? http://www.parkers.co.uk/cars/used-prices/Valuation.aspx?deriv=33004&plate=79#amount=6000&years=3
or have i not read the info correctly.
mine is an 05 plate
APJ
also found this
Cologne , August 26, 2005 - Ford of Europe is making Diesel Particulate Filter (DPF) systems available across the heart of its vehicle portfolio - including retro-fit systems for the majority of diesel-powered Ford vehicles already in customer's hands. New Ford Motorcraft retro-fit systems will be available to suit a wide range of older Ford models.
Ford already offers modern diesel particulate filter (DPF) systems on the new Ford Focus and Focus C-MAX models. A DPF is now standard equipment for Ford's Duratorq 1.6-litre 109 PS TDCi engine, [color="#FF0000"]and optional on the 2.0-litre 136 PS variant[/color]. These systems rely on the use of a liquid additive to enable diesel particulates to oxidise at relatively low temperatures in the filter.
To satisfy the heavy demand for these DPF-equipped models, particularly in Germany , Ford has increased production as a result of increased availability of DPF systems.
Ford of Europe will also continue to develop advanced DPF systems for its next generation Duratorq TDCi engines with higher torque and power outputs exceeding 110 kW (150 PS).
Indicating a DPF was optional on the 2005 2.0TDCI Ford Focus
catch
Yes and did you also find on the web how much Ford Germany where charging for the retro fit DPF's ? Little money and I mean little money compared to what they charge in RIP OF BRITAIN.
APJ
Hey Catch, yeah i am aware of the considerably cheaper DPF's Ford of Germany are using. think somebody mentioned it on this forum recently. Hopefully those prices will filter through to Ford UK soon!
P.S just phoned my local Ford dealer to ask them if my Focus was fitted with a DPF when was built but he said they'd have to have a look at it to tell me for certain.
if it was optional on my type of Focus im praying that its an option that the guy who had the car from new didnt take up! got a horrible feeling it does have a DPF tho as they are pretty common on the MK2 2.0TDCI Focus's. Im having the CAM belt done in a weeks time so gona get the Ford mechanics to look and tell me once and forall if have a b1oody DPF! :-)
catch
I would have thought they could tell you by checking the Vin number, least ways Volvo Vin numbers enabled you to check if the vehicle was fitted with a DPF. And remember Volvo up until the Chinese bought them back in 2010, was a Ford owned company.
goaty
Interesting reading. I have to say I was totally ignorant about the DFP filter. I went shopping for a petrol model and came back a diesel owner for the first time. I have a 1.8 tdci 06 diesel Zetec and by the sounds of it I don't have one of these fitted?!?
johnH
same model and story as mine (petrol to first time diesel) and you dont have a DPF , i just gone past 76k miles and no additive/filter fault and i wont coz there isnt one. i even checked my ford ecat software and it doesnt even have one listed for mine (using VIN).
grahamp
This is from another forum and applies to the 90 / 110 PS 1.6 TDCi engines, but I guess the code applies to other vehicles too...
You can find it indirectly :
90 bhp is stage 4 without a DPF. 109 bhp is stage3 without a DPF and stage 4 with a DPF..
Now look at the Vehicle cert label/VIN plate (right hand B-pillar) then read down the 8 fields on the left portion of the plate, at very bottom (8 down from top) - this box shows the Exhaust emission level code:
K > Stage V
S > 2000 EEC (Stage III)
V > Stage IV + Diesel Particulate Filter (DPF)
7 > Stage IV
If you read "7" your car is stage 4 without DPF and it must be 90 bhp.
if you read "V" your car is stage IV with a DPF then it must be 109 bhp.
if you read "S" its stage III, without a DPF and it must be 109 bhp..
Parf
If you type your reg into the Ford Etis will that tell you if a DPF was fitted. Mines a 2007 2.0 TDCi and when I emailed a Ford dealer he said that it is listing i have one but he would have to look at it and see to be sure.
Although the Etis says nothing about it and it is very detailed on what was fitted.
Parf
Does anyone have a picture of the underneath of their car showing a DPF fitted. i have just looked under mine and all i can see is a long box down the middle of the car and the silencer box before the end pipe.
Karlos
[quote name='grahamp' timestamp='1312980994' post='139405']
K > Stage V
7 > Stage IV
Checked on my 2007 2.0 TDCi and I have a "7" and no DPF, so I'm guessing that applies to all engines.
Parf
I have a 2.0 TDCi 2007 and i also have a 7 but i have a DPF fitted. My DPF is next to the cat at the front of the car so it doesnt require an additive as it gets hot enough to burn it off.
A fitter at Ford said first i dont have one as he checked the space at the rear where it should be, he then took the undertray off and said i do have one but there are no pipes going into it so it doesnt need an additive.
There appears to be a lot of different kinds of DPF's so if you want to know for sure best to take it to a Ford dealer to have a look.
Not great news for me but better than some as at least i dont have to keep filling up the additive at £200 a go. The fitter said they normally clog up around 80k - 90k but ive only done 30k.
Karlos
So in summary then, it's as clear as mud! Lol!
Parf
You got it.
Ive been reading every forum there is trying to see if i have one. I have a DTUK tuning box and they recommended not going over setting 9 if you have a DPF in case of damage so I wanted to know for sure before i cranked it up. As i dont have an additive one i decided to put it on setting B now and hopefully it will be ok.
Take it to a Ford dealer is the only way your going to know for sure, they can tell you which one you have then, if any, as Ford fitted both types to the Focus. Have an MOT or tyres fitted with them and use the line "while its up in the air can you have a look if i have a DPF". Worked for me.
Karlos
Like I've probably said before, with the amount of smoke that comes from my exhaust when pressing on, I don't think there's any way I've got a DPF fitted to mine!
Fire26662
[quote name='Parf' timestamp='1313495682' post='140261']
Uhm I have a 1.6 109bhp I have a catalytic converter AND a DPF combined, The Ford fitter may not have a clue, because the ELOYS tank is actually above the diesel tank, also the ELOYS fluid is NOT pumped into the DPF, it bleeds into the main diesel tank everytime you put fuel in.
