taffg
February 16, 2011, 3:31 pm
[quote name='nicoconnect' timestamp='1297890628' post='114462']
Where would I find the serial number, the one I gave was a number I found attached to my spare key and it is a "T"??? And I live in Spain, would that make a difference??
And yes, I a woman ;o)
well 'nicoconnect' yes i am a woman!
you can try and press channel numbers 6 and 1 together, or 6 and 2 together this may display some data on the radio screen, write this down and see if it contains the serial number starting with the letter 'M' followed by six numbers, if you are lucky and the code is displayed in the data then repost this number and someone can help you out. if not you will need to remove the radio from the console using radio keys which are usually available in good motor parts shops. ensure you get the correct keys for your radio and they should be very cheap. on the rear of the radio you will find the ident plate, on this you will find the serial number.re post as before.
hope this helps
taffg yes i am a man!
