ray844!
February 20, 2011, 1:14 pm
HELP!!
Right got the old arm off not a problem nuts bolts all good, problem i can't get the pin back in that connects the arm to the suspension leg, it will go in 3/4 off the way and no further aand i cant get the pinch bolt back in.
any suggestions welcome
Ray
February 20, 2011, 3:16 pm
[quote name='ray844!' timestamp='1298229252' post='115078']
HELP!!
Ray
i take it you mean the ball joint pin wont go back in to the leg? have you tried putting a jack under it?
ray844!
February 20, 2011, 3:27 pm
[quote name='stef123' timestamp='1298236604' post='115094']
i do yes and yes but it only goes3/4 of the way and no further tried hammer, and cleaning the hole it goes in about three quater and nothing
February 20, 2011, 3:45 pm
[quote name='ray844!' timestamp='1298237239' post='115097']
is the ball joint any different to the old one? seems very strange that it wont go in fully.
ray844!
February 20, 2011, 3:55 pm
[quote name='stef123' timestamp='1298238331' post='115102']
theres no difference i assume it should just go it with out any problem?
February 20, 2011, 4:22 pm
[quote name='ray844!' timestamp='1298238929' post='115103']
are you sure its not fully in? although it may seem otherwise? usually when you jack the arm to fit them into the knuckle they take a bit of jacking and then all of a sudden shift and thats them right home..
what brand is the new arm?
February 21, 2011, 10:28 am
going off a little bit here, how did you find the front bushes of the arm fitted? did the bolt rattle about inside the sleeve until tightened up?
got 2 new arms to fit myself, but it seems there is a little play between the bolt and the sleeve.
cheers
stef
