FordFish
October 28, 2008, 3:13 am
Quick question, my front heated windscreen only works on the passenger side. Does anyone know if this problem should come down to a windscreen replacement company or should be something that a ford dealer should look at? has anyone come across this as a common problem before?
Regards,
Daniel
October 28, 2008, 12:47 pm
check the fuse there is one for each side otherwise you could try to check the wireing connections for the side that does not work.
MrsM
December 8, 2008, 3:13 am
I have the same problem on my CMAX. Do you know where I should look for the wires & connectors?
w2575
February 12, 2009, 5:29 pm
Connectors are under front gutter remove black plastic 2 flat connectors left and right hand side. Screen works in 2 halfs usually its not the fuse , its a whole new windscreen as the wiper motor linkages seem to catch on the connectors , well known problem in focus
