I've been a long time browser , but just signed up as Im in trouble
And after reading a fix or two on hear I through ill try you lot
I will try to give as much info as poss , so please bear with me
1996 1.6 Zetec Escort daily driver no real problems
My car's MOT run's out @ the end of this month so I through ill do a few bits @ the start of the month to get a jump start for the MOT . Got some new rubber on the front corners , a bulb and a whiper blade , also did a filter and fluid change and I noticed a water leak , on further inverstigation it is .....
Yer you got it ... the water pump
Ordered a new w/p and a c/b kit ... cleaned up the said area as my p/s was leaking, striped her down and replaced the w/p and c/b kit after a few half days hear and there in my back garden
so the time to start her up was upon me , so turned the crank 2 full turns and double checked the timing marks ... BANG ON .. wow great feeling pleased with myself , had a cup of tea cookie and a smoke . had to check again so 2 more turns , all lined up aok
let her idle while I finished me tea and smoke ( cookie was nice so it got eaten very quick ) put the heater on just in case air locks , turned her off top up coolant , starts up again fine , so took a little chiled drive , come back and parked up. Couple of hours later I was offf out 4 the night , so jumped in turn the key .. nothing
Now bear with me on this next bit .. she bumped started again after 2 smokey s/m .. does the solenoid engage and dissengage the s/m teeth with the flywheel teeth ? cause it seems to me this is whats going on ?? its not disengaging and thats why it smokes after a whille ?? where does it get the signel to cut power to the s/m and disengage itsself ??
Do you know what that blue wire is that comes from the red power lead from the battery that goes to the plastic s/m connector and then goes into the loom where the earth cable is on the pully's side ? Does that have anything to do with the Passive Anti Theft System ?? Could there be a problem there in reguards to disengaging the s/m and thats why the s/m smoke's
I hope you are still with me lol .. I would be very gratefull if any of you with idears can post your throught's on this as I'm proper :confused:
Ill update this if I try anything else hehe
Thanks people
