[quote name='Lenny' timestamp='1302367739' post='122276']
[size="4"][/size][b][i]Hi all,
I have located the bulb sockets in the front foot wells of the focus dashboard put in the old indicator bulbs from the wing mirrors to try. Also checked the rear of the bulb sockets and there is cables leading from them,
So why wont the light up??
Do I need to add an extra fuse if yes where is the fuse box?
Or
Are the cables leading from the bulb sockets wired to anything at the other end??
When should they light up?
When I put on lights or open the doors or both, really want to get them going please help
[/i][/b]
Strange why they are not working, with my 2002 Foucus Zetec once I found the sockets I just popped two wedge bulbs in and that was it.
The footwell lights are linked to the courtesy light so they should only come on when the doors are opened and go off the same time as the courtesy light, that's how it works on mine Not sure if the newer focus do this differently or have a separate fuse, wouldn't have thought so.
If the courtesy light is working then so should the footwell ones. Hopefully someone will be able to help.
