fordmondy
April 29, 2011, 7:08 am
I have a 2006 2.0 tdci diesel with 43000 miles, regularly serviced. It starts from cold ok everytime.
But intermittently when starting from warm, eg. stopping for newspaper then engine does not always start properly.
It fires staight away as normal but the revs only go up to about 500 (about half normal tickover) and the engine judders like its misfiring or not running on all four.
I can feel this through the car and it sounds really clunky.
Sometimes this will clear on its own after a few seconds and the revs will rise to about 900 (normal tickover).
Other times it will not clear and a switch off is needed.
Restarting can then repeat the fault or it may start normally.
Quickstarting or allowing glow plug time does not seem to make a difference.
Once started up right it will run ok and drive fine.
Pressing on gas pedal when is misfires has no effect.
There are no flashing fault lights, the dash appears as normal.
Thanks for any help.
April 29, 2011, 9:37 am
this is a known common problem on the tdci and ford have a ecu update which should cure it. so talk to T C Harrison about it and get them to update the ecu.
fordmondy
May 7, 2011, 3:51 pm
Rang TC Harrison and the guy said 'what known problem' and that if i'd like to book car in they'd have a look at it, at cost. Trouble is i can't make it do it and it can be several days between each time, and when it does it can clear straight away or i can spend several minutes trying to get it to run right. So don't want to pay ford to look at it and say nothing wrong when i know there is.
Reading through forums have seen quite a few people on about smoke and the EGR valve. Mine does smoke when i floor it. And a test i came across says to warm engine and while idling and apply vacuum (need tool) to EGR pipe and if car runs like a bag of shit or cuts out then valve is opening ok if no difference then valve isn't working.
So i'm wondering if my valve isn't shutting properly when car is warm.
So i've taken EGR valve out (mine has elec plug on it) and its cacked (about half diameter reduced). Have cleaned it and i'm waiting to see if faults again (been 3 days so far).
I'd like to now clean inlet manifold. The very helpful guide i followed for EGR was on ford wiki and to get the manifold off i need to remove 2 electrical plugs. A grey one above manifold and a black one on solenoid bracket in front of manifold. I'm struggling to unplug them and scared i'll break them if i carry on as i can't suss out how to release them. Any help appreciated
May 8, 2011, 9:23 am
when i cleaned the manifold on my tdci i removed the two bolts holding the back plate to the complete solenoid and swung the complete unit out of the way, the grey plug to the cam sensor can also be left in position
itsrelfy
May 9, 2011, 12:52 pm
Hi
I had this on my mondeo, and i got it solved by taking it to my local ford dealer, they updated the ecu software and also re calibrated the injectors, cost about 100 quid all in. the problem never returned.
Regards
Adrian
digidash
May 17, 2011, 6:32 pm
ford service bulletin 34/2006 dated 14 dec 2006....
Should a customer express concern about low idle speed (500-700 rpm) and or no throttle repsonse for between 2 second and 3 minutes depending on vehicle, the probable cause is the minimum drive pulse (MDP) of the injectors, which has drifted excessively at low rail pressure (less than 400 bar). This causes a reduction in fuel delivery versus demand and stops the engine reaching the required idle speed in an acceptable time. The PCM does not detect the excessive MDP drift because the strategy does not learn the MDP at the pressures where the problem occurs.
After some time the idle speed will return to normal (800 rpm) and throttle repsonse will be obtained. This concern can occur when the engine is hot or cold. The issue is recurring.
To rectify this concern a new calibration has been released for service which will vary the quantity of fuel demanded during engine cranking in order to reach the idle latch speed in an acceptable time
maybe quote this before agreeing to pay £80 "diagnostics fee" tell them you know what you want and an extra fee for un-needed diagnostics is unreasonable.
good luck, steve
Jwajw
February 14, 2012, 3:19 pm
Hi I have the exact same problem can you tell me how you got on?
Z3 MON
February 14, 2012, 5:34 pm
ill be on the phone to ford tomorow i think.
cheers for this bit of nifty info digidash
Z3 MON
February 15, 2012, 3:16 am
Just called two seperated Ford dealers re this.
The first one said £108.00 and they will stick upgrade on ECU.
The second aaid they don't do customer diagnosis so would charge £54 to check codes, if its the ugrade that's needed it will be £108 on top of the £54
Think ill try a few others lol
Jwajw
February 15, 2012, 4:06 pm
It's says the update for ecu came out in dec 06, my mondeo is an 07 plate! Would it not already have the update on?
Z3 MON
February 16, 2012, 2:05 am
ah yes it should!
pragmatix
February 16, 2012, 2:36 am
Is 07 the reg date or the build date
Z3 MON
February 16, 2012, 9:42 am
O yer if its an early 07 the chances are it was built in 06 almost defiantly before the service bulletin
Jwajw
February 16, 2012, 3:15 pm
Hello, the reg is 07, I've got it booked into fords in the morning so hoping its gets sorted
Anthony Dyer
May 26, 2012, 6:17 pm
Excact same problem, mine is a 130bhp 55plate with 40750 miles on the clock
[i]I have a 2006 2.0 tdci diesel with 43000 miles, regularly serviced. It starts from cold ok everytime.
Pressing on [url="http://shop.ebay.co.uk/?_nkw=gas+pedal"]gas pedal[/url] when is misfires has no effect.
Thanks for any help. [/i]
[i]by original poster[/i]
2.0 Tdci 130 Problem
