lugo
May 1, 2011, 4:56 am
hi all, had the cam belt changed on my 1.8 derv focus 2 months ago.
recent weeks it has started to smoke badly. under hard acceleration it pushes out heavey black smoke?
exhust is sooted up.
my guess is over fueling am i on right track.
is there any adjustment on feul pump??
your help is much appriciated
andy
Sara Fiesta
May 1, 2011, 12:14 pm
I found this on a site may be the problem i don't know????
A common problem is the EGR valve sticking in the open position. This will cause excessive black smoke from the exhaust and will result in a lack of performance.
lugo
May 2, 2011, 8:43 am
thanks for that where did u find that. performance is fine tho.
having the time to look at it is prob . will have to make some time doing my head in now
May 3, 2011, 8:50 am
The lack of performance tends to be dependant on the presence and state of the DPF filter. Without a DPF you are more likely to keep the power as it is, however with one, if the thing is getting on a bit, you will find that it will be clogged, and that will reduce the power output, as it backlogs on the Turbo, and the exhaust...
Sara Fiesta
May 6, 2011, 4:05 pm
Sorry for the delay in answering, I was researching my problem and I came across a focus known faults list but I didn't save it and now I can't find the site!
cressws1
May 8, 2011, 1:46 am
[quote name='Sara Fiesta' timestamp='1304715933' post='126046']
Was it [url="http://www.bba-reman.com/content.aspx?content=ford_focus_common_problems_and_solutions"]this[/url] one?
Sara Fiesta
May 8, 2011, 7:21 am
Yeah that's the one thanks
lugo
May 10, 2011, 12:35 pm
since been told its a boost problem from what the fault code is saying . still not had chance to take to get it sorted. :-(
Sara Fiesta
May 11, 2011, 2:07 pm
Boost problems, wastegate fault, broken hose what's the air filter like clogged?
Smoke
