chris*3
November 21, 2008, 1:51 am
hi , i got a cmax 2.0 tdci phase IV and when i fill up tank , i got a reading of 440miles with full tank is this normal ?????? thanks for u r help
November 21, 2008, 11:32 am
i dont know the size of the tank on the c max but you should avarage 44-50mpg, so if its a ten gallon tank it sounds about right.
chris*3
November 22, 2008, 4:07 am
[quote name='mintalkin' post='7587' date='Nov 21 2008, 05:42 PM']i dont know the size of the tank on the c max but you should avarage 44-50mpg, so if its a ten gallon tank it sounds about right.[/quote]
thanks for answering me , the size of the tamk is 53 litres
Russ
November 22, 2008, 9:47 am
[quote name='chris*3' post='7603' date='Nov 22 2008, 10:17 AM']thanks for answering me , the size of the tamk is 53 litres[/quote]
Just under 12 gallons. With regards to the computer saying 440 miles i wouldn't rely on that as the chances are once you start driving, that figure will go up and down depending on how and what roads you drive on.......ie expect better consumption on long journeys when you stay at a steady speed and don't change up and down gears. In other words, town driving will be worse than motorway driving! The 440 is probably a starting figure for the computer to work to.
fenris
December 8, 2008, 5:56 am
[quote name='Russ' post='7612' date='Nov 22 2008, 03:57 PM']Just under 12 gallons. With regards to the computer saying 440 miles i wouldn't rely on that as the chances are once you start driving, that figure will go up and down depending on how and what roads you drive on.......ie expect better consumption on long journeys when you stay at a steady speed and don't change up and down gears. In other words, town driving will be worse than motorway driving! The 440 is probably a starting figure for the computer to work to.[/quote]
the figure changes according to 'previous' driving style. Also, the computer isn't very accurate, around town I get 33mpg from my tdci 2.0, but when filling (full to full) it is actually around 38, that's 2-5 miles journeys from cold. On a long run taking it relaxed c 60-70, it's closer to 55 mpg. At the higher end, it overestimates, and at the lower end, underestimates.
Still not figured out why it takes so long to turn over every morning in the cold though, as the batterys fine!
