wilbyforce
November 24, 2008, 4:51 am
I've owned my 3 year-old C-Max since April this year. For a good few months the remote key fob has worked fine but in the last 2 months I've gone through 2 fob batteries. When the batteries are good the fob works normally. Does anyone know if they can malfunction and drain batteries abnormally quickly?
Many thanks.
Russ
November 24, 2008, 11:15 am
[quote name='wilbyforce' post='7672' date='Nov 24 2008, 11:01 AM']I've owned my 3 year-old C-Max since April this year. For a good few months the remote key fob has worked fine but in the last 2 months I've gone through 2 fob batteries. When the batteries are good the fob works normally. Does anyone know if they can malfunction and drain batteries abnormally quickly?
Many thanks.[/quote]
Anything electrical using batteries can and sometimes do drain the batteries. I have a set of verniers that should auto switch off, the screen goes black as if theyre switching off but within a day or two the batteries are dead. All i can do is replace the battery so it sounds like you 'may' need a new keyfob unfortunately. I'd check the connections first though in the fob.
wilbyforce
November 25, 2008, 4:23 am
[quote name='Russ' post='7697' date='Nov 24 2008, 05:25 PM']it sounds like you 'may' need a new keyfob unfortunately. I'd check the connections first though in the fob.[/quote]
Thanks Russ.
c-maxxer
December 8, 2008, 7:47 am
I had a Puma with basically the same key remote. I accidentally went swimming one day with the key in my pocket. After that the battery went flat in a week or so every time I renewed it.
In my case I took the key to pieces, removed the battery and gave the electrical circuits a thorough clean with switch cleaning spray (Servisol). I wiped the key clean, left it overnight, put it back toether and then refitted the battery. the battery then lasted ages.
Worth a try maybe ?
wilbyforce
December 11, 2008, 5:38 am
[quote name='c-maxxer' post='8208' date='Dec 8 2008, 01:57 PM']In my case I took the key to pieces, removed the battery and gave the electrical circuits a thorough clean with switch cleaning spray (Servisol). I wiped the key clean, left it overnight, put it back toether and then refitted the battery. the battery then lasted ages.
Worth a try maybe ?[/quote]
Thanks, I'll keep that in mind. It's about 3 weeks since I put a new Energiser battery in and it seems fine. I'm hoping that I've just learned that (IMO) Tesco own brand batteries are rubbish.
Key Battery
