Full Version: Headlight Replacement
Pete1971
Need to replace a headlight, is this as easy as unscrewing the 3 visible bolts, sliding out the unit, disconnecting the electrics and replacing with new unit? Don't particularly want to pay a dealership if I can easily do the job myself, anyone any experience of this on a Fusion?
digidash
Exterior Lighting - Headlamp Assembly Fusion 2002.75 (06/2002-)
Print Report An Error
Removal and Installation
Removal
Unscrew and remove the headlamp bolts.
CAUTION: Make sure that the headlamp guide lugs are not damaged.
Detach the headlamp from the hood lock panel.
Pull the headlamp out of its lower mounting.
Pass the upper guide lug of the headlamp forward under the fender.
Disconnect the headlamp assembly plugs.
Installation
Connect the headlamp connector.
NOTE: Clean the lens with a damp cloth to prevent the build-up of electrostatic charge, which could cause dust to stick to the plastic lens.
NOTE: Make certain that the headlamp is correctly located in the mounting.
Fit the headlamp assembly.
Pass the upper guide lug of the headlamp in under the fender.
Engage the headlamp in the lower mounting.
Pull the top part of the headlamp forwards until it engages in the mounting.
Screw in the headlamp bolts.
Headlamps - Align (both sides)
For additional information, refer to Headlamps - Align (both sides) in this section
hope this helps, regards steve
Pete1971
Cheers, going to give it a go at the weekend (weather permitting of course)
[quote name='digidash' timestamp='1306172522' post='128579']
Removal
Installation
Full Colour Version: Headlight Replacement
