Full Version: 1999 Ford Puma dash light bulb change?
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford Puma Club
soph
Hi!
Don't know if anyone can point me in the right direction..
How do i change the light bulb for the dashboard on my Ford Puma?
Cem
[quote name='soph' post='7972' date='Dec 1 2008, 05:56 PM']Hi!
Thanks[/quote]
If your doing the speedo the surrounding has to come off, should be screws holding them in, undo them one by one, you have have to drop the steering colom if adjustable, also may need to take off the top steering colom cover, not sure if nessesary in the puma,
should be staring at the speed clock once all removed, should be 2 screws holding the clock in one on each side, once undone pull the clock out towards you slowly(may need a tug) once the clock out behind it are L.e.d bulbs that twist out (be sure to take the rite ones out, i say test on one two then slot back in dash to make sure its the rite ones then go from there,
any probs ask :P
