ratpie
June 14, 2011, 10:45 am
I own a Ford Focus TDCI 2.0 mk2 (2009) and the mileage on it is about 12,000km. I have been getting a warning on my dashboard saying "Engine Malfunction" for a while now. I cannot figure out why this happens because it seems to happen randomly. Every time this warning pops up I will also hear an alarm, but I can still drive normally, and if I step on the brake (about 15% pressed) the warning message disappears and everything goes back to normal. It freaked me out the first few times, so I took it to Ford and told them about my problem, and all they did was do an OBD check and told me everything is normal.
The intervals between each warning seems to be completely random too, sometimes I don't get the warning for a full week, and other times I get the warning more than six times in a short drive. I have no idea what might be causing this problem and I would be very thankful if someone helps me out!
My car has had a few minor modifications only. I've changed the mufflers, the air filter, and the wheels. I don't think these modifications could have caused the problem. In fact, I think I started getting the warnings before I changed the muffler.
In addition, most of the driving I do in under heavy traffic jam because I live in Bangkok (Thailand), so maybe this might have affected the DPF's regeneration? I am open to any suggestions, thank you all very much!
June 15, 2011, 3:08 am
What exactly is the warning on the dashboard? if you can give a message from the trip computer when the error is there, and which lights are illuminated that will help. Also if you can pull over with the error still on screen, and access the trip computers on board diagnostics (top thread on the focus forum) you may see the error code...
ratpie
June 15, 2011, 6:33 am
[quote name='jeebowhite' timestamp='1308125302' post='131840']
wow I wasn't expecting a reply this quick. Thank a lot for the reply!
All it says on my trip computer is "engine malfunction" with a hazard logo and a siren-like noise goes off. Apart from that I don't recall seeing any lights being illuminated. I've uploaded a picture of it for you to see.
And like I said before, when I get the warning everything still functions normally and when I step on the brakes, the warning message will disappear. I've used the on board computer to check for any messages and it says nothing. I've also tried running the diagnostic mode to look for any DTC codes: also nothing. So the only thing I can try is to operate the trip computer while the warning message is still there (before I press on the brake), but if I remember correctly I am not able to use the trip computer while the message is showing.
This is my first car and I really like it, please let me know anything that I can try! thank you so much!
June 15, 2011, 7:02 am
hmmm, not great. I cant see what the light is thats illumited between fuel and temp. However, you can always set the car off in diagnostics mode before you start driving, then if an error occurs, and you get something light up, you can continue to drive as safely as possible and circulate through to the DTC Codes... that might get you somewhere.
The fact the engine "malfunctions" yet continues, sounds to me like a sensor giving a duff reading... The fact the brake pedal is pushing the alert, I wonder if its a short out somewhere...
Try sticking the card in diagnostics mode, before you go out for a drive, if possible, try to circulate through the diagnostics, otherwise, if you can let the car roll to a halt on the motorway hard shoulder without losing the alarm, then go through everything...
this is a weird one...
ratpie
June 15, 2011, 8:02 am
[quote name='jeebowhite' timestamp='1308139375' post='131892']
Thanks for your suggestion, I will start my car in diagnostic mode and hope for the warning to pop up the next time I drive. lol. I will let you know if I have any progress over the coming weeks.
By the way, I've just read about a software update for my trip computer, I might take it to the Ford guys and have them update my car, maybe it'll eliminate the problem. Thanks again for your help!
johnH
June 15, 2011, 10:16 am
at 12k you shouldnt be getting the DPF Fault just yet (if fitted). i can relate to this...i used to get this randomly aswell. untill i changed the fuel filter. i figured it was fuel related as when i got the fault i tried booting the car and it would slightly kangaroo at around 80mph...
im not sure what fuel quality is like in thailand...but maybe your fuel filter has committed it. cheap to fix...cost me £10 for a new one.
June 15, 2011, 10:29 am
Its the fact that the engine continues to work and doesnt stall that is throwing me, thats why im not too sure its the fuel filter!
Sara Fiesta
June 15, 2011, 10:59 am
I had an engine malfuction warning pop up and i took my TDci 1.6 to ford they found nothing major wrong they did an update so it worth a try it's free under warranty.
johnH
June 15, 2011, 12:29 pm
[quote name='jeebowhite' timestamp='1308151777' post='131910']
mine never stalled during the time. just kangaroo'd a little. fine at slower speeds though.
merlin
June 15, 2011, 3:02 pm
Are you or have you recently put shell fuel in??
ratpie
June 16, 2011, 1:28 am
[quote name='merlin' timestamp='1308168170' post='131957']
I have used shell v-power a couple a times before. why? do you not recommend it?
ratpie
June 16, 2011, 1:32 am
[quote name='johnH' timestamp='1308151012' post='131908']
Thanks I will give that a try! I don't know much about the fuel quality in Thailand, but I know that my focus creates a lot of black smoke when I boot it. And Since I've got dual exhaust fitted on my WHITE car, I have to wash the rear of the car every week!
I think you might be right, I really think its down to the type of fuel I use as well.
Also, I don't think I've experienced any "kangaroo"ing
June 16, 2011, 3:10 am
[quote name='johnH' timestamp='1308158998' post='131924']
aaaah, mine was just completely fubare'd then! lol!
Good old Fuel Filters...
ratpie
June 16, 2011, 3:35 am
I've fixed the problem! It turns out there is a connection problem with the brake sensor of my car!
June 16, 2011, 7:37 am
[quote name='ratpie' timestamp='1308213340' post='132032']
Glad it was a simple! Enjoy your new found comfort and renewed trust!
merlin
June 16, 2011, 7:53 am
Hope thats it solved for good. Regards fuel, mine started acting as tho about to stall after 10-20 minutes. But not on every run. Never did but makes you nervous when overtaking at 70 when it started hesitating!! Had used shell v-power but after switching back to BP ultimate it has failed to re-appear. (Only appeared after a few squirts of shell.) Plus an old forum on the fuel made me suspicious.
