Johnerae
June 18, 2011, 9:50 am
We have issues with the CD6000 audio. It will not find any stations when trying to tune it, we can play the stations that are loaded already, but it looses reception when we drive it around. We had the aeriel replaced, and if I take the aeriel out it will not play any stations at all (logically). We have tried 4 other CD6000's and all seem to have the same issue. We went to Ford and they suggested we clean the connections on the back, which I did - it had no affect. Any idea's anyone?
jonboy607
June 18, 2011, 10:43 am
[quote name='Johnerae' timestamp='1308408612' post='132294']
Have you replaced the aerial base along with mast? It may be worth checking the connections on the base before replacing it thou!
June 19, 2011, 8:09 am
agree with jonboy,the ford aerial base are well known for rusting so check and clean up all the connections.
Johnerae
June 19, 2011, 9:55 am
Hi, yes, we had the whole thing replaced - Aerial base, new aerial and co-ax cable between the aerial base and audio unit. If I take the aerial connection out of the back of the radio when it is switched on but out of the dashboard, then the radio goes off completely - so the aerial works.
cuke
June 19, 2011, 10:25 am
Hi, have you tried powering it off then on again, ie disconnect it from the cars wiring harness. Remember you'll need the code first..
Chris
alz
June 20, 2011, 1:45 pm
sound like you need to test the arial wire, for conection to the arial, take out the interior light to gain access then check it with a meter,it may not be conected,if all ok check for continuity in the arial wire.
