Richardhart90
June 18, 2011, 3:39 pm
Hi all,
I've just bought a focus 1.8 Tddi and i cant seem to get the trip meter to work !
I've pushed the reset button but it just wont count as i drive.
Any help would be apreciated.
Richard
mjt
June 19, 2011, 4:55 am
Is it stuck at zero? If so I would suspect that the button or the switch it operates is stuck in.
I assume the speedo is working ok and the ordinary odometer is clocking up?
Richardhart90
June 19, 2011, 5:19 am
[quote name='mjt' timestamp='1308477340' post='132380']
Thanks for reply, the speedo is working ok and odometer is clocking up, i wonder if the reset button is stuck in , as i done the Self-Diagnostic Mode - Instrument Cluster test once and i cant seem to do it anymore !
How do releive the butotn?, when you push it in, it does seem to click when pushed?
Richard
mjt
June 19, 2011, 5:50 am
It does sound like a switch problem although if it clicks it may not be stuck so might be broken internally. I'm afraid I can't be more help as I've never had an instrument cluster out. If it's a surface-mount component it might not be feasible to replace it.
Hopefully someone else may be able to offer more help.
June 19, 2011, 9:02 am
[quote name='mjt' timestamp='1308480622' post='132387']
indeed its part of the internals of the cluster and wont be fixable well you can but 9 times out of 10 you break the cluster so ide get a new cluster from a scrapyard if it bothers you or just live with it and see if it pops out on its own
